Is there a model or formula that can describe the output value of a DAC?
The user observed nonlinearity in the output of the MAX538ACSA+ DAC, particularly at low data codes, which is attributed to a zero-code deadband. The datasheet specifies linearity from code 11 upward, and the user can improve accuracy by ignoring lower codes or applying open-loop calibration techniques. The user also noted periodic errors with Tminor = 64 and Tmajor = 256, suggesting a consistent internal pattern that may be modeled for further correction.
Product Number: max538acsa, max538
Hi, I used a multimeter (with 10 μV accuracy) to record the output of a DAC (PN: MAX538ACSA+), and compared the actual values with the theoretical ones. I found that when the data code is relatively small, the ratio (actual/theoretical) is much lower. Around a data code of 500, the ratio approaches 0.999. Is this normal? Is there a model or formula that can describe this variation so that I can accurately determine the DAC's output value? Thanks.
More Content
