Strong EMC design
When drawing a load current at either rail, the output voltage headroom with respect to that rail is limited by the 25 Ω typical channel resistance of the DAC channel.
For example, when sinking 1 mA,the minimum output voltage = 25 Ω × 1 mA = 25 mV.
If I need to sink 25mA current, does that mean that the minimum output voltage is 625mV, and in practice I need to supply 20mA current, what happens to the output voltage
zpandangan - Moved from High-Speed DACs to Precision DACs. Post date updated from Wednesday, March 19, 2025 5:26 AM UTC to Wednesday, March 19, 2025 1:34 PM UTC to reflect the move.
zpandangan - Moved from High-Speed DACs to Precision DACs. Post date updated from Wednesday, March 19, 2025 1:34 PM UTC to Wednesday, March 19, 2025 1:34 PM UTC to reflect the move.
Hi LCJ603 ,
I have moved your query about AD5593R to the Precision DACs community. Someone here should be able to assist you.
Zaeefa
Hi LCJ603 ,
Your computations are correct. However, in the AD5593R Datasheet, under the DAC performance specifications, 25mA is already the short-circuit current in typical conditions.
You may also check Figure 26 for the DAC Output Sink and Source Capability.
May we know your target application so we can further assist you?
Flynn
I need drive 120ohm resistor ,and supply 20ma max
