I only used the AD5755's A and B channels to output 24mA current, and the C and D channels were not used, what should I do with the pins REST_x, COMPDCDC_x, and IOUT_x/VOUT_x, and can I leave it floating or grounded?
Thanks for your answer!
KCC's Quizzes AQQ304 - A pure logic
1. Quote of the month: "I am not lazy, I'm just in energy-saving mode" - unknown
2. Quiz AQQ304 about finding a pure logic puzzle
Mike is looking at Anne, but Anne is looking at Paul.
Mike is married, but Paul is not.
Question:
Is a married
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
Hi YolandaO .
For unused channels, the DAC output is disabled by default (DAC Control Register OUTEN=0). You can leave IOUTx and VOUTx floating. For RSETx, you can select the internal resistor (RSET=1) for the selected DAC channel. For COMPDCDCx, if you are using the internal compensation, it's ok to leave it open as well. But if you're using external resistor for compensation, a ~50 kΩ resistor in series with a 10 nF dc-to-dc compensation capacitor to ground is recommended.
Flynn
Thank you very much for your guidance, and I would like to ask you to help me see if the schematic of the AD5755 is correct, as the size of the PCB is limited, so I want to minimize the layout area of the AD5755
