Zedboard cannot recognize EVAL-AD3552RFMC1Z
Product Number: Eval-ad3552
I'm trying to use the EVAL-AD3552RFMC1Z using the Zedborad as the controller.And I follow the wiki (https://wiki.analog.com/resources/eval/user-guides/dac/ad3552r_eval_zed) and the user guide (Evaluating the AD3552R, 16-Bit, Dual-Channel, Current Output DACPDF).
I followed the instructions in the wiki and completed up to the IIO Oscilloscope section. I was able to send commands to the Zedboard and receive responses successfully, so I believe the Zedboard should be programmed correctly.
According to the user guide, if the connection is correct, I should be able to see an icon like Fig. 1 in the "Attached Hardware" section of the ACE software. However, the ACE software cannot recognize the EVAL-AD3552RFMC1Z , which is shown in Fig. 2.
Fig.1 The "Attached Hardware" section of ACE in the User Guide             Fig.2 The "Attached Hardware" section of ACE in my computer
Additionally, there are some information prompts on the EVAL-AD3552RFMC1Z board.
  • Green: Power up correct
  • Red: Alter trigger
  • Blue: Dual SPI enable
  • Purple: SYNC DUAL SPI enable
which are the statuses corresponding to different LED colors on the EVAL-AD3552RFMC1Z board.
But the LEDs on my EVAL-AD3552RFMC1Z board don't light up, so I think the Zedboard don't recognize EVAL-AD3552RFMC1Z.
Fig.3 The LEDs(in the red rectangle) don't light up
      is currently taking a look at this query.
    Den
  • This Linux image still does not support the communication with ACE. Configuration must be done using IIO Oscilloscope and waveforms can be transferred using IIO lib in Python.
    We are moving to a single Linux image supporting all the products, but the EVAL-AD3552R is not added yet.
  • Thanks for your answers!
    Accroding to the "IIO Oscilloscope" section of the wiki(https://wiki.analog.com/resources/eval/user-guides/dac/ad3552r_eval_zed), I should see the waveform on the ADI IIO Oscilloscope,but there is nothing in the software.Could this be because I am not connecting the EVAL-AD3552R to an oscilloscope?
    Also, the LEDs on the EVAL-AD3552R do not light up. Is this a problem?
  • The Oscilloscope window is for ADCs. For DACs, we can only send a vector of data and check the waveform on the oscilloscope.
    I think that the evaluation board should power up when Linux boot completes. There is a signal coming from the FPGA that turns on the converters. I will check this on my side.
  • The evaluation board should power on when boot is complete. Make sure that V_ADJ is set to 1.8V.
  • The V_ADJ is indeed set to 1.8V.
    Wolud you like to give a s
    uccessful boot message of the zedboard? I want to confirm if there is a problem with my boot.
    And here is my boot message Arrow down
    U-Boot 2018.01-21442-gf06dec3cab (Feb 15 2024 - 17:01:09 +0200), Build: jenkins-development-build_uboot-30
    Model: Zynq Zed Development Board
    Board: Xilinx Zynq
    Silicon: v3.1
    DRAM:  ECC disabled 512 MiB
    MMC:   sdhci@e0100000: 0 (SD)
    SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB
    *** Warning - bad CRC, using default environment
    In:    serial@e0001000
    Out:   serial@e0001000
    Err:   serial@e0001000
    Net:   ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
    eth0: ethernet@e000b000
    reading uEnv.txt
    407 bytes read in 24 ms (15.6 KiB/s)
    Importing environment from SD ...
    Hit any key to stop autoboot:  0
    Device: sdhci@e0100000
    Manufacturer ID: 3
    OEM: 5344
    Tran Speed: 50000000
    Rd Block Len: 512
    SD version 3.0
    High Capacity: Yes
    Capacity: 14.8 GiB
    Bus Width: 4-bit
    Erase Group Size: 512 Bytes
    reading uEnv.txt
    Loaded environment from uEnv.txt
    Running uenvcmd ...
    Copying Linux from SD to RAM...
    reading uImage
    7000848 bytes read in 411 ms (16.2 MiB/s)
    reading devicetree.dtb
    16250 bytes read in 30 ms (528.3 KiB/s)
    ** Unable to read file uramdisk.image.gz **
    ## Booting kernel from Legacy Image at 03000000 ...
       Image Name:   Linux-5.10.0-98180-g99149f838b0f
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    7000784 Bytes = 6.7 MiB
       Load Address: 00008000
       Entry Point:  00008000
       Verifying Checksum ... OK
    ## Flattened Device Tree blob at 02a00000
       Booting using the fdt blob at 0x2a00000
       Loading Kernel Image ... OK
       Loading Device Tree to 1eb13000, end 1eb19f79 ... OK
    Starting kernel ...
    Booting Linux on physical CPU 0x0
    Linux version 5.10.0-98180-g99149f838b0f-dirty (ppop@romlx5) (arm-xilinx-linux-gnueabi-gcc.real (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0.20220819) #6 SMP PREEMPT Tue Feb 27 17:42:22 EET 2024
    CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    OF: fdt: Machine model: Xilinx Zynq ZED
    OF: fdt: earlycon: stdout-path /amba@0/uart@E0001000 not found
    Memory policy: Data cache writealloc
    cma: Reserved 128 MiB at 0x16800000
    Zone ranges:
      Normal   [mem 0x0000000000000000-0x000000001fffffff]
      HighMem  empty
    Movable zone start for each node
    Early memory node ranges
      node   0: [mem 0x0000000000000000-0x000000001fffffff]
    Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff]
    percpu: Embedded 15 pages/cpu s29900 r8192 d23348 u61440
    Built 1 zonelists, mobility grouping on.  Total pages: 130048
    Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1
    Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    mem auto-init: stack:off, heap alloc:off, heap free:off
    Memory: 367204K/524288K available (10240K kernel code, 775K rwdata, 7300K rodata, 1024K init, 308K bss, 26012K reserved, 131072K cma-reserved, 0K highmem)
    rcu: Preemptible hierarchical RCU implementation.
    rcu:    RCU event tracing is enabled.
    rcu:    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
            Trampoline variant of Tasks RCU enabled.
    rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    efuse mapped to (ptrval)
    slcr mapped to (ptrval)
    L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
    L2C-310 erratum 769419 enabled
    L2C-310 enabling early BRESP for Cortex-A9
    L2C-310 full line of zeros enabled for Cortex-A9
    L2C-310 ID prefetch enabled, offset 1 lines
    L2C-310 dynamic clock gating enabled, standby mode enabled
    L2C-310 cache controller enabled, 8 ways, 512 kB
    L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
    random: get_random_bytes called from start_kernel+0x338/0x4d8 with crng_init=0
    zynq_clock_init: clkc starts at (ptrval)
    Zynq clock init
    sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
    clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
    Switching to timer-based delay loop, resolution 3ns
    clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
    timer #0 at (ptrval), irq=25
    Console: colour dummy device 80x30
    Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    CPU: Testing write buffer coherency: ok
    CPU0: Spectre v2: using BPIALL workaround
    CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Setting up static identity map for 0x100000 - 0x100060
    rcu: Hierarchical SRCU implementation.
    smp: Bringing up secondary CPUs ...
    CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    CPU1: Spectre v2: using BPIALL workaround
    smp: Brought up 1 node, 2 CPUs
    SMP: Total of 2 processors activated (1333.33 BogoMIPS).
    CPU: All CPU(s) started in SVC mode.
    devtmpfs: initialized
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    pinctrl core: initialized pinctrl subsystem
    NET: Registered protocol family 16
    DMA: preallocated 256 KiB pool for atomic coherent allocations
    thermal_sys: Registered thermal governor 'step_wise'
    hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 32, base_baud = 3125000) is a xuartps
    printk: console [ttyPS0] enabled
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    mc: Linux media interface: v0.10
    videodev: Linux video capture interface: v2.00
    jesd204: found 0 devices and 0 topologies
    FPGA manager framework
    Advanced Linux Sound Architecture Driver Initialized.
    clocksource: Switched to clocksource arm_global_timer
    NET: Registered protocol family 2
    tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
    TCP: Hash tables configured (established 4096 bind 4096)
    UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
    hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
    workingset: timestamp_bits=30 max_order=17 bucket_order=0
    io scheduler mq-deadline registered
    io scheduler kyber registered
    zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
    dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
    dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
    brd: module loaded
    loop: module loaded
    Registered mathworks_ip class
    spi-nor spi0.0: found s25fl256s1, expected n25q128a11
    spi-nor spi0.0: s25fl256s1 (32768 Kbytes)
    5 fixed-partitions partitions found on MTD device spi0.0
    Creating 5 MTD partitions on "spi0.0":
    0x000000000000-0x000000500000 : "boot"
    0x000000500000-0x000000520000 : "bootenv"
    0x000000520000-0x000000540000 : "config"
    0x000000540000-0x000000fc0000 : "image"
    0x000000fc0000-0x000002000000 : "spare"
    MACsec IEEE 802.1AE
    libphy: Fixed MDIO Bus: probed
    tun: Universal TUN/TAP device driver, 1.6
    libphy: MACB_mii_bus: probed
    macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 34 (00:0a:35:00:01:22)
    usbcore: registered new interface driver asix
    usbcore: registered new interface driver ax88179_178a
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver net1080
    usbcore: registered new interface driver cdc_subset
    usbcore: registered new interface driver zaurus
    usbcore: registered new interface driver cdc_ncm
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    usbcore: registered new interface driver uas
    usbcore: registered new interface driver usb-storage
    usbcore: registered new interface driver usbserial_generic
    usbserial: USB Serial support registered for generic
    usbcore: registered new interface driver ftdi_sio
    usbserial: USB Serial support registered for FTDI USB Serial Device
    usbcore: registered new interface driver upd78f0730
    usbserial: USB Serial support registered for upd78f0730
    ULPI transceiver vendor/product ID 0x0451/0x1507
    Found TI TUSB1210 ULPI transceiver.
    ULPI integrity check: passed.
    ci_hdrc ci_hdrc.0: EHCI Host Controller
    ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
    ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: EHCI Host Controller
    usb usb1: Manufacturer: Linux 5.10.0-98180-g99149f838b0f-dirty ehci_hcd
    usb usb1: SerialNumber: ci_hdrc.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    i2c /dev entries driver
    adv7511 0-0039: supply avdd not found, using dummy regulator
    adv7511 0-0039: supply dvdd not found, using dummy regulator
    adv7511 0-0039: supply pvdd not found, using dummy regulator
    adv7511 0-0039: supply bgvdd not found, using dummy regulator
    adv7511 0-0039: supply dvdd-3v not found, using dummy regulator
    at24 1-0050: supply vcc not found, using dummy regulator
    at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (1.1.1)
    gspca_main: v2.14.0 registered
    cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
    Xilinx Zynq CpuIdle Driver started
    failed to register cpuidle driver
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    ledtrig-cpu: registered to indicate activity on CPUs
    hid: raw HID events driver (C) Jiri Kosina
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
    mmc0: new high speed SDHC card at address aaaa
    mmcblk0: mmc0:aaaa SC16G 14.8 GiB
     mmcblk0: p1 p2 p3
    axi_sysid 45000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    axi_sysid 45000000.axi-sysid-0: [ad3552r_evb] on [zed] git branch <main> git <4b8f3f06f7763410bdc5be21a1cf82e9d4d1f3fd> clean [2024-02-21 21:16:17] UTC
    fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
    usbcore: registered new interface driver snd-usb-audio
    axi-i2s 77600000.axi-i2s: probed, capture enabled, playback enabled
    NET: Registered protocol family 10
    Segment Routing with IPv6
    sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    NET: Registered protocol family 36
    zynq_pm_remap_ocm: no compatible node found for 'xlnx,zynq-ocmc-1.0'
    zynq_pm_suspend_init: Unable to map OCM.
    Registering SWP/SWPB emulation handler
    [drm] Initialized axi_hdmi_drm 1.0.0 20120930 for 70e00000.axi_hdmi on minor 0
    axi-hdmi 70e00000.axi_hdmi: [drm] Cannot find any crtc or sizes
    clk: Not disabling unused clocks
    ALSA device list:
      #0: HDMI monitor
      #1: ZED ADAU1761
    random: fast init done
    EXT4-fs (mmcblk0p2): recovery complete
    EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    VFS: Mounted root (ext4 filesystem) on device 179:2.
    devtmpfs: mounted
    Freeing unused kernel memory: 1024K
    Run /sbin/init as init process
    systemd[1]: System time before build time, advancing clock.
    systemd[1]: systemd 247.3-7+rpi1+deb11u6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    systemd[1]: Detected architecture arm.
    Welcome to Kuiper GNU/Linux 11.2 (bullseye)!
    systemd[1]: Set hostname to <analog>.
    systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
    systemd[1]: /lib/systemd/system/iiod.service:14: Invalid environment assignment, ignoring: $IIOD_EXTRA_OPTS=
    systemd[1]: Queued start job for default target Graphical Interface.
    random: systemd: uninitialized urandom read (16 bytes read)
    systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    systemd[1]: Created slice system-modprobe.slice.
    [  OK  ] Created slice system-modprobe.slice.
    systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
    systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    systemd[1]: Listening on fsck to fsckd communication Socket.
    [  OK  ] Listening on fsck to fsckd communication Socket.
    systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    systemd[1]: Condition check resulted in POSIX Message Queue File System being skipped.
    systemd[1]: Mounting RPC Pipe File System...
    systemd[1]: Mounting Kernel Debug File System...
    systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
    systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    systemd[1]: Starting Restore / save the current clock...
    systemd[1]: Starting Set the console keyboard layout...
    systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
    systemd[1]: Starting Load Kernel Module configfs...
    systemd[1]: Starting Load Kernel Module drm...
    systemd[1]: Starting Load Kernel Module fuse...
    systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    systemd[1]: Starting Journal Service...
    systemd[1]: Starting Load Kernel Modules...
    systemd[1]: Starting Remount Root and Kernel File Systems...
    systemd[1]: Starting Coldplug All udev Devices...
    systemd[1]: run-rpc_pipefs.mount: Mount process exited, code=exited, status=32/n/a
    systemd[1]: run-rpc_pipefs.mount: Failed with result 'exit-code'.
    systemd[1]: Failed to mount RPC Pipe File System.
    [FAILED] Failed to mount RPC Pipe File System.
    See 'systemctl status run-rpc_pipefs.mount' for details.
    systemd[1]: Dependency failed for RPC security service for NFS client and server.
    [DEPEND] Dependency failed for RPC …ice for NFS client and server.
    systemd[1]: rpc-gssd.service: Job rpc-gssd.service/start failed with result 'dependency'.
    systemd[1]: Dependency failed for RPC security service for NFS server.
    [DEPEND] Dependency failed for RPC …curity service for NFS server.
    systemd[1]: rpc-svcgssd.service: Job rpc-svcgssd.service/start failed with result 'dependency'.
    systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    systemd[1]: Finished Restore / save the current clock.
    [  OK  ] Finished Restore / save the current clock.
    systemd[1]: modprobe@configfs.service: Succeeded.
    systemd[1]: Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module configfs.
    random: crng init done
    random: 7 urandom warning(s) missed due to ratelimiting
    systemd[1]: modprobe@drm.service: Succeeded.
    systemd[1]: Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module drm.
    systemd[1]: modprobe@fuse.service: Succeeded.
    systemd[1]: Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Module fuse.
    systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Reached target NFS client services.
    [  OK  ] Reached target Remote File Systems (Pre).
    [  OK  ] Reached target Remote File Systems.
    EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
             Mounting Kernel Configuration File System...
             Starting Apply Kernel Variables...
    [  OK  ] Finished Set the console keyboard layout.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Apply Kernel Variables.
             Starting Flush Journal to Persistent Storage...
             Starting Load/Save Random Seed...
             Starting Create System Users...
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Finished Create System Users.
    [  OK  ] Finished Coldplug All udev Devices.
             Starting Helper to synchronize boot up for ifupdown...
             Starting Create Static Device Nodes in /dev...
             Starting Wait for udev To …plete Device Initialization...
    [  OK  ] Finished Helper to synchronize boot up for ifupdown.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Starting Show Plymouth Boot Screen...
    [  OK  ] Started Show Plymouth Boot Screen.
    [  OK  ] Started Forward Password R…s to Plymouth Directory Watch.
    [  OK  ] Reached target Local Encrypted Volumes.
    [  OK  ] Found device /dev/ttyPS0.
    [  OK  ] Found device /dev/disk/by-partuuid/5c29002e-01.
    [  OK  ] Finished Wait for udev To Complete Device Initialization.
             Starting File System Check…isk/by-partuuid/5c29002e-01...
    [  OK  ] Started File System Check Daemon to report status.
    [  OK  ] Finished File System Check…/disk/by-partuuid/5c29002e-01.
             Mounting /boot...
    [  OK  ] Mounted /boot.
    [  OK  ] Reached target Local File Systems.
             Starting Set console font and keymap...
             Starting Raise network interfaces...
             Starting Preprocess NFS configuration...
             Starting Tell Plymouth To Write Out Runtime Data...
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Tell Plymouth To Write Out Runtime Data.
    [  OK  ] Finished Set console font and keymap.
    [  OK  ] Finished Preprocess NFS configuration.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Finished Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Finished Raise network interfaces.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started CUPS Scheduler.
    [  OK  ] Started Daily apt download activities.
    [  OK  ] Started Daily apt upgrade and clean activities.
    [  OK  ] Started Periodic ext4 Onli…ata Check for All Filesystems.
    [  OK  ] Started Discard unused blocks once a week.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily man-db regeneration.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Paths.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on CUPS Scheduler.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on Erlang Port Mapper Daemon Activation Socket.
    [  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
    [  OK  ] Listening on triggerhappy.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Analog Devices power up/down sequence...
             Starting Save/Restore Sound Card State...
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Regular background program processing daemon.
    [  OK  ] Started D-Bus System Message Bus.
             Starting dphys-swapfile - …unt, and delete a swap file...
             Starting Remove Stale Onli…t4 Metadata Check Snapshots...
    [  OK  ] Started fan-control.
             Starting Fix DP audio and X11 for Jupiter...
             Starting Creating IIOD Context Attributes......
             Starting Authorization Manager...
             Starting DHCP Client Daemon...
             Starting LSB: Switch to on…nless shift key is pressed)...
             Starting LSB: rng-tools (Debian variant)...
             Starting System Logging Service...
             Starting User Login Management...
             Starting triggerhappy global hotkey daemon...
             Starting Disk Manager...
             Starting WPA supplicant...
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Reached target Sound Card.
    [  OK  ] Started System Logging Service.
    [  OK  ] Started triggerhappy global hotkey daemon.
    [  OK  ] Finished Fix DP audio and X11 for Jupiter.
    [  OK  ] Started DHCP Client Daemon.
    [  OK  ] Finished dphys-swapfile - …mount, and delete a swap file.
    [  OK  ] Started Authorization Manager.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started WPA supplicant.
    [  OK  ] Started LSB: Switch to ond…(unless shift key is pressed).
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Network is Online.
             Starting Modem Manager...
             Starting CUPS Scheduler...
    [  OK  ] Started Erlang Port Mapper Daemon.
             Starting HTTP based time synchronization tool...
             Starting Internet superserver...
             Starting /etc/rc.local Compatibility...
             Starting OpenBSD Secure Shell server...
             Starting Permit User Sessions...
    [  OK  ] Started Internet superserver.
    [  OK  ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
    [  OK  ] Started LSB: rng-tools (Debian variant).
    [  OK  ] Started /etc/rc.local Compatibility.
    [  OK  ] Started User Login Management.
    [  OK  ] Started Unattended Upgrades Shutdown.
    [  OK  ] Finished Permit User Sessions.
             Starting Light Display Manager...
             Starting Hold until boot process finishes up...
             Starting Manage, Install and Generate Color Profiles...
    [  OK  ] Started HTTP based time synchronization tool.
    [FAILED] Failed to start VNC Server for X11.
    Raspbian GNU/Linux 11 analog ttyPS0
    analog login: root (automatic login)
    Linux analog 5.10.0-98180-g99149f838b0f-dirty #6 SMP PREEMPT Tue Feb 27 17:42:22 EET 2024 armv7l
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Thu Jan 16 10:17:16 GMT 2025 on ttyPS0
    root@analog:~#
  • Well, I have solve the problemJoy.
    I replaced a new SD card and found that the zedboard can connect to the EVAL-AD3552R normally...
