AD5314 OverVoltage Protection
The user is experiencing output loss and DAC stoppage issues when operating the AD5314 at 6V, which is outside the specified 2.5V to 5.5V range. The support engineer suggests that the unpredictable behavior at 6V could be causing these problems and recommends a power-on reset to recover. The user confirms that the DAC has been working fine for 10 years at 6V but has recently encountered frequent issues.
Category: Datasheet/Specs
Product Number: AD5314
Hi.
When using a VDD=6V power supply, there may be a loss of output.
Recover with a power-on reset
I know I'm using it outside of the specifications(VDD:2.5 V to 5.5 V).
Does this device provide any protection?
  • Hi  ,
    The AD5314 is specified to operate at 2.5V to 5.5V, and all datasheet parameters are guaranteed only within this range. While the absolute maximum rating for VDD is 7V, running the device at 6V exceeds the recommended range and can result in unpredictable behavior.  Could you share more info about your application and why 6V is required in your design?
    Br,
    Den
  • Hi Den
    Thank you for your answer
    I've been using it for 10 years with no problems using a 6V power supply.
    Recently, there have been many problems with DAC stopping.
    No matter what I write it doesn't work, but it works when I turn it back on.
    There may be other reasons, but the DAC is definitely down.
    What are the conditions that cause the DAC to stop working?
More Content
