Non Linearity in rheostat mode
The user is experiencing non-linear resistance readings when controlling an AD8400 digipot with an Arduino Uno R3 via SPI. The final answer suggests using a voltage follower at the wiper terminal or forcing a voltage on terminal W and measuring the voltage at terminal B to GND for accurate linearity measurement. The accompanying answer notes that the thread was moved to the Precision DACs forum for better assistance.
Category: Datasheet/Specs
Product Number: AD8400
I am controlling the AD8400(1 kohm) digipot with Arduino Uno R3 using SPI interface. My connections are as follows:
Digipot <-> Arduino
CS(3) <->10
SDI(4) <-> 11
CLG(5) <->13
VDD(6) <-> 5v
I am checking the resistance across terminal W and B using multimeter after giving input between 0 to 255.But the resistance obtained is not varying linearly and it also exceeds the Resistor Nonlinearity((-4) -(+4) LSB) provided in datasheet.
Below is the graph obtained for values between 0-255
Blue line indicates the observed values
Red line is for the equation:
Resistance = 43.2 + (Data/ 255) * (1000)
_____________________________________________
Below is the code used:
#include <SPI.h> // include the SPI library
#define slaveSelectPin 10 // set pin 10 as the slave select for the digital pot
int address = 0; //addr bits = 0)
int value = 72; // value can be anything between 0 to 255
void setup() {
  pinMode(slaveSelectPin, OUTPUT);// set the slaveSelectPin as an output:
  Serial.begin(115200);
  SPI.begin(); // initialize SPI:
void DigitalPotWrite(int addr, int val){
  digitalWrite(slaveSelectPin, LOW);
  SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE1)); //initialises SPI clock speed, mode and bit order
  SPI.transfer(addr);
  SPI.transfer(val);
  digitalWrite(slaveSelectPin, HIGH);
  SPI.endTransaction();
void loop() {
  digitalWrite(slaveSelectPin, HIGH); // ensure default CS stays high for now
  DigitalPotWrite(address, value);
  delay(5000); //abitrary delay
Can someone please check what could be the error and how to reduce it??
Thread Notes
More Content
