Hi
I am about to test a 16-bit dac to produce a 1kHz sinewave ( probably I am going to use the AD5061).
I will perform an FFT to evaluate different solutions.
I found this very interesting guide adi-data-conversion.pdf (analog.com) and I have some questions on it. Which is the source of the 2nd,3rd... harmonics? What are exactly these nonlinearities? What is the main effect given by the DAC resolution?
I understand that sampling produces the images and the sample rate affects the position of the images. Then we have the zero-hold giving the sinc. What is the effect of DAC resolution? is this the finite resolution the reason of these harmonics
Thanks and best regards
