Question about commnads
Category: Datasheet/Specs
Product Number: AD5686
Dear  Forum
Im using the AD5686 as wavefor generator. I need some confirm about commands use.
I would like:  - Load all 4 ch with 4 different data
                     -Assert the LDAC low ,so, all out are generated at same moment.
If I undersood good, i need to:
1) Senda data   with command 0001,and address DAC A. This will fill the shift reg A
2) Same for other   just change the data and address.This will fill the shift register ..address..
3)Now, Setting LDAC Low, for minimimum 15ns ;  will   transfer data from Shift Reg x to Data Reg x (the out) at same time.
4)The distance beetwen 2 SPI transfer is circa 870ns; this means i can fill DAC B after >circa 870ns +15ns I filled DAC A.
Is this correct ?
Thanks for your time.
Roberto
Thread Notes
