Enquiry for part AD5392BSTZ-5 (SO# 187426)
Category: Datasheet/Specs
Product Number: AD5392BSTZ-5, AD5392
Customer needs the documents as below for customs clearance.
Per customer:
We require supporting documents in relation to or stating
      the following specifications for product, Analog Devices AD5392 8-channel,
      14-bit voltage output DAC:
      a)'adjusted update rate' (in mega samples per second (MSPS));
      b)'Spurious Free Dynamic Range' (SFDR) (in dBc) (carrier) when
      synthesising a full scale analogue signal of 100 MHz or the highest full
      scale analogue signal frequency specified below 100 MHz.
      Technical Notes
      1.'Spurious Free Dynamic Range' (SFDR) is defined as the ratio of the rms
      value of the carrier frequency (maximum signal component) at the input of
      the DAC to the rms value of the next largest noise or harmonic distortion
      component at its output.
      2.SFDR is determined directly from the specification table or from the
      characterisation plots of SFDR versus frequency.
      3.A signal is defined to be full scale when its amplitude is greater than
      -3 dBfs (full scale).
      4.'Adjusted update rate' for DACs:
      a)For conventional (non-interpolating) DACs, the 'adjusted update rate' is
      the rate at which the digital signal is converted to an analogue signal
      and the output analogue values are changed by the DAC. For DACs where the
      interpolation mode may be bypassed (interpolation factor of one), the DAC
      should be considered as a conventional (non-interpolating) DAC.
      b)For interpolating DACs (oversampling DACs), the 'adjusted update rate'
      is defined as the DAC update rate divided by the smallest interpolating
      factor. For interpolating DACs, the 'adjusted update rate' may be referred
      to by different terms including:
      _input data rate
      _input word rate
      _input sample rate
      _maximum total input bus rate
      _maximum DAC clock rate for DAC clock input.
      5.'Settling time' means the time required for the output to come within
      one half bit of the final v"
Please help to advise whether can support.
Thanks
Regards
  • Hi  .
      is currently checking this query and will get back to you soon.
    Best Regards,
    Den
  • Hi
    for conventional DACs, there can be two ways to approach update rate. First one is to consider both the input data rate and the settling time. Second would be to disregard the input data rate and consider only the settling time. This is only possible if the input data rate is faster than the settling time. See the image below for an illustration.
    For case 1) input update rate (time) @max clock frequency = t7+ t4 + 23*t1 + t21 = 754ns while settling time is 8us max, for an update rate of ~0.114 MSPS
    For case 2) settling time of 8us max for an update rate of 0.125 MSPS
    For SFDR, unfortunately we do not have data for this particular generic.
    Ian
