Hello, I'm sending 24-bit data to the LTC2610 DAC with STM32F103. I'm not seeing any voltage at the DAC output. I'm using the SPI communication protocol. I would appreciate your assistance. I have made several modifications to the SPI configuration, but still no DAC output is visible.
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2023 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define DAC_CS_PIN GPIO_PIN_12
#define DAC_CS_PORT GPIOB
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI2_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
void DAC_SendData(uint32_t data)
uint8_t byte1 = (data >> 16) & 0xFF;
uint8_t byte2 = (data >> 8) & 0xFF;
uint8_t byte3 = data & 0xFF;
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET);
HAL_SPI_Transmit(&hspi1, &byte1, 1, 100); // Yüksek baytı
HAL_SPI_Transmit(&hspi1, &byte2, 1, 100); // Orta baytı
HAL_SPI_Transmit(&hspi1, &byte3, 1, 100); // Düşük baytı
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET);
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
//uint32_t digitalValue = 0x0F7FFC; //v2 = 0x1F7FFC, v3 = 0x3F7FFC, v4=0x4F0000;
//uint32_t digitalValue = 0xFFFFFF;
//uint32_t digitalValue = 0xF00000;
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_SPI2_Init();
/* USER CODE BEGIN 2 */
uint8_t b1 = 0x0F;
uint8_t b2 = 0xFF;
uint8_t b3 = 0xFC;
uint8_t b4 = 0x10;
uint8_t b5 = 0xFF;
uint8_t b6 = 0xFC;
uint8_t b7 = 0x0F;
uint8_t b8 = 0x00;
uint8_t b9 = 0x00;
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
// Digital değeri DAC'ye gönder
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_RESET);
HAL_SPI_Transmit(&hspi2, &b1, 1, 100); // Yüksek baytı
HAL_SPI_Transmit(&hspi2, &b2, 1, 100); // Orta baytı
HAL_SPI_Transmit(&hspi2, &b3, 1, 100); // Düşük baytı
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_SET);
HAL_Delay(100);
HAL_SPI_Transmit(&hspi2, &b4, 1, 100); // Yüksek baytı
HAL_SPI_Transmit(&hspi2, &b5, 1, 100); // Orta baytı
HAL_SPI_Transmit(&hspi2, &b6, 1, 100); // Düşük baytı
HAL_Delay(100);
HAL_SPI_Transmit(&hspi2, &b7, 1, 100); // Yüksek baytı
HAL_SPI_Transmit(&hspi2, &b8, 1, 100); // Orta baytı
HAL_SPI_Transmit(&hspi2, &b9, 1, 100); // Düşük baytı
HAL_Delay(100);
HAL_Delay(100);
HAL_SPI_Transmit(&hspi1, &b4, 1, 100); // Yüksek baytı
HAL_SPI_Transmit(&hspi1, &b5, 1, 100); // Orta baytı
HAL_SPI_Transmit(&hspi1, &b6, 1, 100); // Düşük baytı
HAL_Delay(100);
HAL_SPI_Transmit(&hspi1, &b7, 1, 100); // Yüksek baytı
HAL_SPI_Transmit(&hspi1, &b8, 1, 100); // Orta baytı
HAL_SPI_Transmit(&hspi1, &b9, 1, 100); // Düşük baytı
HAL_Delay(100);
//HAL_Delay(100);
//DAC_SetValue(v2);
//HAL_Delay(1000);
//DAC_SetValue(v3);
//HAL_Delay(1000);
//DAC_SetValue(v4);
//HAL_Delay(1000);
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
* @brief SPI2 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN SPI2_Init 0 */
/* USER CODE END SPI2_Init 0 */
/* USER CODE BEGIN SPI2_Init 1 */
/* USER CODE END SPI2_Init 1 */
/* SPI2 parameter configuration*/
hspi2.Instance = SPI2;
hspi2.Init.Mode = SPI_MODE_MASTER;
hspi2.Init.Direction = SPI_DIRECTION_1LINE;
hspi2.Init.DataSize = SPI_DATASIZE_16BIT;
hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi2.Init.NSS = SPI_NSS_HARD_OUTPUT;
hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi2.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SPI2_Init 2 */
/* USER CODE END SPI2_Init 2 */
* @brief GPIO Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
