Hi all, I have the AD5686R evaluation board (AD5686RSDZ). All the setup was done with no SDP. I set my jumpers as so.
PWRSEL to EXT_SUP as I use external 3.3v and a good clean ground.
REF none to use internal.
P1 in-place
I tied
LDAC low
RESETB high
RSTSEL low
Vio high
I see I'm getting a nice constant SPI transmission verified with a scope and logic analyzer. Also have a scope on the output DAC 1,2,3,4
I'm sending 0x31, data High, data Low and 0x32, data High, data Low
I see a good waveform that comes and goes at random intervals. It can be shown up to 1 minute at times, and then absent for another. Or show up and go flat after a few seconds. Nothing I do seems to influences this. Also to note both DAC are independent of each other in respect to this problem. One can be ok were the other may not. I know the data from the SPI is good, so it must have to do with the DAC generating the output. The data is sent 12MHz at a sample rated of 100Hz. Each packet 1uS apart.
Anyone have a a thought?
Edit Notes
added a note.[edited by: ulao at 4:24 PM (GMT -4) on 22 May 2023]
