Problems with ad 5372 ebz evaluation board control program.
Product Number: AD-5372EBZ
Hey guys. I;m trying to make a python program, in order to control the aformentioned board through SPI. The problem is that the board seems to ignore some of the command that i load. What i mean is that if i load function with two commands, it might execute one of none of them.I always set LDAC low when loading a command and reset low and then high during start up.
dev=0
bus=0
LDAC_pin = 17
BUSY_pin = 22
CLR_pin = 27
RESET_pin = 4
gpio.setwarnings(False)
def setup_gpio():
gpio.setmode(gpio.BCM)
gpio.setup(LDAC_pin, gpio.OUT)
gpio.setup(RESET_pin, gpio.OUT)
gpio.setup(CLR_pin, gpio.OUT)
gpio.setup(BUSY_pin, gpio.IN)
reset()
clear()
def reset():
gpio.output(RESET_pin, 0)
time.sleep(0.001)
gpio.output(RESET_pin, 1)
def clear(enable=None):
if enable is None:
if clear_state is True:
enable = False
else:
enable = True
if enable is True:
gpio.output(CLR_pin, 0)
clear_state = True
else:
gpio.output(CLR_pin, 1)
clear_state = False
def loadDAC(keep=False):
gpio.output(LDAC_pin, 0)
if keep is False:
time.sleep(0.001)
gpio.output(LDAC_pin, 1)
def cleanUp():
spi.close()
gpio.cleanup()
def dacCommandTest(bus,dev,command,dacGroup,dacChannel):
Vref = 3
offsetCode = 0
M = 65535
C= 32768
Vout= 6
Vmax=4*Vref*(65535-4*offsetCode)/(2^16) # Vout should be in this range, given Vref
Vmin=4*Vref*(-4*offsetCode)/(2^16) # Vout should be in this range, given Vref
byte1=command|dacGroup|dacChannel
dacCode=math.ceil(Vout*(2**16)/(4*Vref)+4*offsetCode)
inputCode=math.floor((dacCode-C+(2**15))*(2**16)/(M+1))
d = struct.pack('<H', inputCode)
data= [0, 0, 0 ]
data = [byte1, d[1], d[0]]
if connected ==1 :
spi.open(bus,dev)
spi.mode = 0b01
spi.xfer3(data)
loadDAC()
spi.close()
print('>> CHANNEL '+str(dacChannel)+' in group '+str(int(dacGroup)/8-1)+', is set to : '+ str(Vout)+' Volts ')
def setupOffset(bus,dev,offsetRegister):
byte1=offsetRegister
offsetCode=0
dataZero=0
d = struct.pack('<H', offsetCode)
if connected ==1 :
spi.open(bus,dev)
spi.mode = 0b01
spi.xfer3(data)
loadDAC()
spi.close()
def offsetConfigure():
setupOffset(bus, dev, reg_Offset0)
time.sleep(0.001)
setupOffset(bus, dev, reg_Offset1)
time.sleep(0.001)
if __name__ == '__main__':
spi=spidev.SpiDev()
setup_gpio()
time.sleep(0.001)
offsetConfigure()
time.sleep(0.001)
dacCommandTest(bus,dev,reg_X,all_group,all_ch)
time.sleep(0.001)
dacCommandTest(bus,dev,reg_X,group_0,ch_0)
cleanUp()
