AD5253 Dual Supply Setup
I was hoping to get some help setting up the AD5253 in a Dual Supply configuration.
It tested successfully using single supply setup (5V), but in order to control a negative output (COONN15A:  0-> -2V), I need to use the dual supply setup.
When I use the below setup, I can connect successfully to my script, yet when I run the command to control the wiper taps (also below), I receive an I2C error. I realize that without the full script you will not be able to fully understand why the I2C error appears, but I was hoping that you could look over the setup I have used below and advise me on whether I have made a mistake.
This is the Setup that I have used:
Thank you very much,
Twahidi
The specific function to control resistance:
def
setResistance(self, value: int = 63): # self.getCurrentAndVoltage() bytes_out = int(value) // User inputs tap value from 0-63 for full range of 50K resistor self.i2cWrite(0x5A, [0x00, bytes_out]) // AD1 SET LOW, AD0 SET HIGH resWA = ((64 - bytes_out) / 64) * 50000 + 75 return (resWA) // Prints out expected resistance
REFERENCES:
Single supply setup:
WP/AD0 -->5v on USB microchip
DGND/AD1 --> GND on USB microchip
SCL-->SCL on USB microchip
SDA -->SDA on USB microchip
Link to MC1663 Programmable Microchip Schematic (used for I2C communication):
https://ww1.microchip.com/downloads/en/DeviceDoc/MCP1663-USB-Programmable-Power-Supply-Reference-Design-Users-Guide-DS50002722A.pdf
Relative Schematic:
Custom Power Supply Negative Output subsection:
  R36( 100K mechanical POT) being replaced by AD5253
