Hi all
I want please to check the maximum clock rates of AD5628/AD5648/AD5668 (As mentioned in the datasheet it utilize s a versatile 3-wire serial interface that operates at clock rates of up to 50 MHz). Please more information ??
Thank you
Hi all
Thank you
You are correct. The maximum clock frequency for the serial interface is 50MHz. What other information do you need? Please let me know.
Ian
Thank you for answer
I need a DAC with high maximum clock frequency (up 100MHz ) . if you have any suggestions please let me know. Thank you for your help.
Best regards
I need exactly a PMOD or FMC boards with DAC outputs with high speed (will be connected to Zedboard fpga). Any suggestion please.
Thank you
I found in your website ad9467-fmc-250ebz that can be used with zedboard. I wonder if you have DAC with same sampling rate.
Thank you
Is there an output data rate and dac resolution that you are targetting here? This might be in the domain of high-speed DACs. I'll get someone from the team to look into it more. It would be best if you could provide more of your requirements.
Ian
I look for high speed DAC 12bit/14 bit with a conversion rate of up to 250 MSPS, with 1 or 2 D/A channels.
I need the DAC to communicate between zedboard FPGA and other hardware devices (with sma connectors).
Thank you
Best regards
We have the AD9745 (12-bit serial) and AD9746 (14-bit serial) 250MSPS dual chanel high-speed DACs. Both with eval boards, that can be interfaced FMC controller board if you add-on the adapter board.
Another is 210MSPS, parallel, single-channel AD9742 (12-bit) and AD9744 (14-bit). The eval board for these two support FMC w/o the adapter board.
Ian
