Question about AD5422AREZ
Im currently building a PCB with the AD5420AREZ and starting to evaluate it, but Im concerned that the delivery time for the AD5420 is getting longer.
So Im also considering the AD5422AREZ, which is a similar product, and I'm thinking of mounting it on the same PCB.
Im not use the voltage output of the AD5422. I have some questions about the replacement.
5pin: CLEAR SELECT
The 5pin of the AD5420 PCB is connected to GND, so CLEAR SELECT is connected to GND when mounted. The voltage output is not used, any problem?
17pin: Ccomp
Since the 17pin of the PCB is OPEN, Ccomp will be OPEN. Is there any problem?
21pin: VOUT, 22pin: +Vsense
The 21pin and the 22pin of the PCB are connected to AVdd through a capacitor.
Is it safe to connect +Vout and +Vsense to AVdd through the capacitor as well? Is it better to remove the capacitor? (Vout and +Vsense are OPEN)
23pin: -Vsense
The 23pin of the PCB is OPEN so Vsense will also be OPEN. Is there a problem?
Are there any other points I should be aware of when replacing the AD5422?
Kazu
    •  Super User
    on Oct 4, 2021 3:47 AM
    HI Kazu,
    5pin: CLEAR SELECT
    No problem with this.
    17pin: Ccomp
    No problem with this. comp is for vout only.
    Better to open the capacitor to avoid noise and stray current leakage.
    23pin: -Vsense
    If vout will not be used entirely, it is OK.
    I think you've pretty much covered it. I understand we have some supply issues at the moment. Don't hesitate to contact us or your local FAEs for supply and technical concerns.
    Ian
