I read from the data sheet of AD5761, the spi communication frequency can be up to 50 MHz. My question is what is the lower limit of AD5761 spi communication frequency. Thanks.
Ideally, in SPI, there is no lower limit as long as the minimum timing standards are met. I personally have used SPI in 1KHz clock freq. Is there a special requirement in your application where you'll use a very slow clock speed?
Ian
Think you very much for your reply. I would like to use optocoupler (10Mbit/s 6n137) to isolate spi. And I think maybe i should set sclk to 1MHz, which is 1/10 of 10M.
Taining Zhang
