My customer want to use a DAC with voltage output for supplying voltage to target device on their tester,
And they was used AD5532 to their old tester.
But the spec. of target devices are changed , so they need new voltage output DAC supporting +/- 25V output range.
Would you recommend your voltage output DAC for supporting +/- 25V output range?
Or would you suggest recommended solution for supporting +/- 25V output range? (Need supporting multi channel, small size, Supplying +/- 25V range to target device)
Se-woong
PS. Could they use AD5535B solution to support -25V range?
