AD5544 - Temperature Drift of Resistors
I'd like to generate a DAC output voltage that is greater than the reference voltage I provide to the DAC. Referencing figure 22 of the datasheet, I believe I can do so by adding an external resistor in series with Rfbx that increases the gain of the transimpedance amplifier. The problem I can see with this is that the full-scale range of the DAC will drift as Rfbx varies in resistance due to fab variations or temperature. I see in the datasheet that the resistance of Rfbx will vary from 4k to 8k depending on the device. But how does it vary over temperature?
Peter
