AD5721R Output Range vs Supply Voltage
I can't find an "output swing" vs supply voltage spec for the AD5721R, only a list of its selectable output ranges and its max/min supply voltages.
My question is how much if any "overhead" do I need to provide in the analog supplies in order to get a particular output. Say I want ±5V output, I assume I cannot just use a ±5V supply, I need to provide, say, a ±7V supply, right?
Julia
  • Hi Julia,
    There is a "headroom" spec with load and range conditions on page 4 of the datasheet. Basing on that, +/- 6V supply should be enough for your +/-5V Output.
    Ian
