dac8800FPZ glitch
I am using the old DAC8800 8 Channel DAC on a project, its pretty basic where I pass an 8 bit value to channel 1 of the DAC8800
The problem I have discovered is the ladder inside the chip appears to be incorrectly built.
Ie.
V1RH, V2RH, VDD set to 12v
V1RL, V2RL,/CLK, VSS set to 0V
/CLR set to +5v
SDI Data in
Clk Data In
Load on completion
Address 000 = Channel 1
Data 255     =     10.86v
Data 254     =     10.67v
Data 253     =     10.73v     - Voltage goes up
Data 252     =     10.46v
Data 251     =     10.61v     - Voltage goes up
Data 250     =     9.90v
Data 249     =     10.14v    - Voltage goes up
This appears to continue until we are less than decimal 64
To verify that my software is correct, I setup a breadboard with switches to manually verify this and the results were the same.
Any ideas??
Darren
The chips is labelled
DAC8800
F#0904
P1585598.1
  • Your voltages are low across the board, so I suspect something else is going on.  Have you verified this on more than one channel?  What is the load on the output?  The DAC has ~12k ohms output resistance, so it cannot really drive a load very well.  Remove all loading on the output and test again, and also check the other channels to see if the same thing is happening.  Also check for any changes on the power supply.  Since you are using the supply as the reference, any change there will affect the output voltage.
    Tim
  • The output of channel 1 is connected to the +input of an LM358 opamp. I have also tried other channels (unloaded) apart from connecting my fluke meter (high impedance load) to each output. I get the same result. The 12v dc supply is fed from a 7812 linear regulator and the output has been checked with a CRO and is stable.  I have 25pcs and all exhibit the same problem, am I overlooking something obvious as the circuit is not that complicated!
  • A closer look at the datasheet has (most likely) revealed the issue.  The REF inputs (high side) have to be at least 4v from the positive rail.  Thus, with a 12 volt supply, you're limited to 8v input on the reference.  You've most likely got the output stage saturated.  Can you provide a lower reference voltage and run the test again?
    Tim
  • Hi Tim,
    I changed the supply regulator to 15v and adjusted the reference to 10v the problem actually appears to have deteriorated (see below)
    VDD = 15v
    Vrefh = 0v (both)
    Vrefl = 0v (both)
    VSS = 0v
    Data
    255 = 11.24v
    254 = 11.14v
    253 = 10.25v
    252 = 11.02v
    251 = 9.76v
    250 = 10.08v
    249 = 9.68v
    248 = 10.81v
    247 = 9.40v
    246 = 9.51v
    245 = 8.99v
    244 = 9.79v
    243 = 8.91v
    242 = 9.37v
    241 = 9.17v
    240 = 10.45v
    and so on...
    Attached is a schematic, I have chaged the 7812 to a 7815 in this latest test.
  • Hi-
    I moved this thread to the Precision DACs community.  Please continue the discussion here.
    AndyR
    EngineerZone Community Manager
  • Hi Daliseau,
    I had hoped Tims headroom suggestion would have solved it.
    So you have a single supply system:
    Vdd=15V
    Vrefh=10V
    Vrefl=0V
    Vss=0V
    Has this issue been resolved ?
  • Hi Liam,
    Yes it is a single supply system with the parameters you outlined
    Tim raised a good point regarding the Ref voltage but unfortunatly it appears to be unrelated to this issue.
    ie. The problem is still evident, any clues?
    thanks
    Darren
  • Hi Darren
    Have you scoped all SPI writes to the part to makes sure that the data you are writing is actually seen by the part ?
    I assume you have checked all grounds / supplies etc,
    You could try the specified single supply setup on page 2 of datasheet:
    Vdd=12V
    Vss=0V
    VrefH=5V
    Vrefl=0V
    See if this gives any further improvement.
    -Liam
  • Hi Liam,
    I am currently on leave until the end of the month, however prior to heading off on holidays I pulled the prototype unit (that was in storage after moving) and it worked perfectly, this has an older IC from a different batch!
    Without swapping out the DAC8800 from the prototype, I suspect I have a bad batch of IC's.
    Will post an update on my return.
    Darren
  • Hi Darren,
    All these parts are production tested to the highest standard before leaving the factory - however it's possible the chip is damaged through some other method.
    -Liam
