Use OP AMP(AD797) as DAC(AD5445) output buffer
Dear all,
Please help me:
I want to use an OP AMP(AD797) as the buffer of DAC(AD5445).
We need Positive output voltage (0~3.3V) , but the reference design use one more OP AMP and LDO (ADR03).
I just want use just one OP AMP as I-to-V converter.
I found this configuration:
My question:
(1) RL is need?
(2) Pin RFB connect to ?
Is the following scheme OK?
Thank you in advance!
Best Wishes,
William
  • William,
    I don't beleave either configuration is going to work for you, but have not benched either to see. I think at best you're going to see only 1/2 the range.
    As per the datasheet, the standard way to get to the possitive ourput is as shown. I don't see a way around the need to generating a negative reference into the DAC, since the amp is going to invert the signal.
    https://ez.analog.com/cfs-file/__key/communityserver-discussions-components-files/427/320e8aecea7c39045f981ddffdb9a6be.html
    Thank you,
    EZ Admin
