AD5757 & AD5755
1- I do not want to use Dynamic Power Control in AD5757 and AD5755. Can I connect my 12 volt to Vboost or only min voltage is 15 volt.
2- In AD5755 can I do not connect AVss to -volt And the Vout_x is only 0-5 or 0-10 volt.
    on May 7, 2012 4:21 PM
    Hi-
    I moved this discussion about the AD5757 and AD5755 to the Precision DACs Community.  Someone here should be able to assist you with this.
    AndyR
    EngineerZone Community Manager
    on May 8, 2012 4:24 PM
    Yes if you are not using Vboost, this pin can be tied to 12V no problem.
    We do not specify this as a uni-polar part.  Is it not recommended to leave any supply as a "Do Not Connect".
    You can connect Vss to GND however.  For the particular outputs that you mention there will be a footroom issue, but outside of this it will be linear.  We do not specify the part under these voltage conditions.
    If you use the AD5755-1 which has the sense in buffer disconnected this footroom is far reduced in the order of 20-30mV.
    Michael (PDA Applications)
