AD5422 Power Sequencing?
i currently have an evaluation board of the AD5422, and noticed that when i supply the AVdd first before the DVcc it only gives me an error of +/- 2mV(voltage output: 0-5V range) and when i supply DVcc first before AVdd it gives me an error of about 2V.
Based from my data that I got from the evaluation, it seems that need to power up the Analog first then the DVcc which was not mentioned on the ad5422 datasheet. I already checked whether there is something wrong with the data that the DAC is receiving and also the read back that the ADC is providing.
attachments.zip
    on May 7, 2012 4:28 PM
    Hi-
    I moved this question about the AD5422 to the Precision DACs Community.  Someone here should be able to assist you.
    AndyR
    EngineerZone Community Manager
    on May 8, 2012 3:26 PM
    Power Supply Sequencing has been tested on this part and has shown no issues.  I've also re-tried your conditions here and seen no issues.
    It appears that you are changing the output range of the part from 0 - 5V to 0 - 10V at some point too.
    Can you send me a list of the commands you are sending to the part.  Also can you downloaded SW version 1.2 from the AD5422 webpage so that we are on the same version.
    I can share my screen with you at a convenient time to go through.
    Michael (PDA Applications)
