AD5667 I2C interface  C code example
My name is Asha Singh. I am trying to communicate with a AD5667 device via the I2C interface.
I was wondering if you have a sample C or C++ or C# or Matlab code for this I2C interface (read and write )
Asha
Parents
  • // Distributed with a free-will license.
    // Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
    // AD5667
    // This code is designed to work with the AD5667_I2CDAC I2C Mini Module available from ControlEverything.com.
    // https://www.controleverything.com/content/Digital-Analog?sku=AD5667_I2CDAC#tabs-0-product_tabset-2
    #include <stdio.h>
    #include <stdlib.h>
    #include <linux/i2c-dev.h>
    #include <sys/ioctl.h>
    #include <fcntl.h>
    void main()
    	// Create I2C bus
    	int file;
    	char *bus = "/dev/i2c-1";
    	if((file = open(bus, O_RDWR)) < 0)
    		printf("Failed to open the bus. \n");
    		exit(1);
    	// Get I2C device, AD5667 I2C address is 0x0E(14)
    	ioctl(file, I2C_SLAVE, 0x0E);
    	// Select DAC and input registers, write 2 bytes of data(0x1F)
    	char config[3] = {0};
    	config[0] = 0x1F;
    	config[1] = 0x80;
    	config[2] = 0x00;
    	write(file, config, 3);
    	sleep(1);
    	// Convert the data
    	float voltage = ((config[1] * 256 + config[2]) / 65536.0) * 5.0;
    	// Output data to screen
    	printf("Voltage : %.2f V \n", voltage);
    This is sample of C I2C code to control AD5667
Reply
    // AD5667
    #include <stdio.h>
    #include <stdlib.h>
    #include <fcntl.h>
    void main()
    	// Create I2C bus
    	int file;
    		exit(1);
    	config[0] = 0x1F;
    	config[1] = 0x80;
    	config[2] = 0x00;
    	sleep(1);
    	// Convert the data
Children
No Data
