AD5732 not responding
I'm working on making this thing work for the last couple of days but nothing helps. I double and triple checked the electrical connections and I am 100% positive they are OK.
My host MCU is an Atmel 8bit.
My send "word" function looks like so:
CS_LOW
spi_send_byte(data1);
spi_send_byte(data2);
spi_send_byte(data3);
CS_HIGH
LDAC_LOW
_delay_ms(1);
LDAC_HIGH
CS_HIGH
CS is typed to the SYNC pin, LDAC -> LDAC.
Following data words were sent (in this order):
dac_send_word(0b00001100,0b00000000,0b00000101); -- set range
dac_send_word(0b00010000,0b00000000,0b00010101); -- power control
dac_send_word(0b00000100,0b11111111,0b11111110); -- dac register
dac_send_word(0b00011101,0b00000000,0b00000000); -- control register
If someone can find a fundamental flaw in this I would like to hear! Thanks!
  • Hi t.stern,
    I am not an expert at programming, so I cannot help much with the code.
    Just a quick comment: Do you bring SYNC low before you start writting to the part to set the range,,..?
    From your code, it seems like you maintain SYNC high, or it could be a typo here:
    LDAC_LOW
    _delay_ms(1);
    LDAC_HIGH
    CS_HIGH
    Do you have a timing plot that shows how the data is sent to the part?
    Estibaliz
  • The actual sequence is as follows:
    CS_LOW
    CS_HIGH
    LDAC_LOW
    _delay_ms(1);
    LDAC_HIGH
    CS_HIGH
    So SYNC is brought low (CS_LOW macro) before sending 3 x byte commands via spi_send_byte(). After these are sent (finished), SYNC is brought up (CS_HIGH macro). After that LDAC is pulled low (LDAC_LOW macro), after a short delay LDAC is brought up high again. The last CS_HIGH is a mistake in the code, however does not do anything as the pin is already high.
    To get a real timing diagram I would need to wire the rig to my logic analyzer. I might get around doing so but it will take a while.
    Thank you,
    EZ Admin
