Please teach me about AD5662.
Vout=Vref * (D/65,536)
In this value, what gain is output buffer amplifier?
I think that the gain=2 when Vfb pin is connected with Vout pin.
Which is the output in that case 0- Vref or 0-2Vref ?
Thank you.
Thank you.
The reference is internally divided by two and later amplified by the output buffer.
Consequently, Vout = Vref * D / 65536
the inverting pin terminal is offered to remotely sense the output voltage and compensate any voltage drops for example in a long cable.
Let me know if something is not clear, please
Miguel
Thanks your reply.
Please let me clarify it.
Is the case where resistance is not put between Vfb pin and Vout pin the following expression?
Do it become the gain of the above-mentioned expression when the following doesn't put resistance between Vfb pin and Vout pin?
Thank you,
Kotoo
Can anyone make a response?
Thank you.
Msamera-san,
My question became clear.
Thanks so mach.
