I can’t let the VoutB (AD5732) port output analoy voltage. Who can help me? Thanks a lot!
<1>setup both of DACs
<2>setup the A-channel and B-channel
<3> then setup the DAC register
Only VoutA output analoy voltage.@
Moved to more appropriate community
Hi, Cao.
It would greatly help me understand your problem if you could provide a schematic diagram. Please include working supply, references, and logic levels. Would you also be able to answer some questions regarding your problem?
Mark
Could you give me more help. thanks a lot.
AGND and DGND is connected.
Hi, Cao.
Everything looks good to me. I just have some questions. What is the difference between AVC_IN_O and DVC_IN_O?How are you measuring the output voltage on the part? Where is pin 5 of the part connected to?
Mark
