POWER-UP/DOWN SEQUENCE of AD5220.
The user inquired about the pull-up/pull-down configuration for the _CS, U/D_, and CLK pins of the AD5220. The final answer recommends pulling _CS down to ground and U/D_ and CLK up to 5V via resistors. The accompanying answer thanked the support engineer for the response.
Hello.
I have a question about POWER-UP/DOWN SEQUENCE of AD5220.
Should I make the pin terminal the pull-up or a pull-down?
1. _CS (pull-up or a pull-down?)
2. U/D_ (pull-up or a pull-down?)
3. CLK (pull-up or a pull-down?)
Thank you!
Best regards.
