AD5668 support in Linux with ARM Cortex-A8
Hi all,
Greetings !!!
I am interfacing EVAL-AD5668SDCZ with TI-AM335x EVAL Board.
I am using Linux-3.12.30.
I have done integration and driver compilation and successfully got sysfs entries also.
i am able to send the data to DAC register.
But the problem is I am not getting proper output voltage at TP4 (or) OUTPUTA.
I am following the below excellent wiki link from ANALOG DEVICES.
AD5064 IIO Quad-Channel DAC Linux Driver [Analog Devices Wiki]
I am getting only Maximum 197.2 mv at the output A.
I am using internal_vref = 2500000 , and below are the sysfs values.
$ echo 10000 > /sys/bus/iio/devices/iio\:device0/out_voltage0_raw
$ cat /sys/bus/iio/devices/iio\:device0/out_voltage0_raw
10000
$ cat /sys/bus/iio/devices/iio\:device0/out_voltage0_scale
0.038140
U = out_voltage0_raw * out_voltage0_scale = 10000 * 0,038140 mV = 381,14 mV
According to the above wiki link, i have to get 381.14mv  mv, but i am only getting 197.2v.
If I am giving 100 to out_voltage0_raw, I am getting 16 mV.
What could be the problem ? any jumper settings i have to check in  EVAL-AD5668SDCZ
could any body help me in this ?
Thank in advance.
Regards ,
Bhaskar
