Connecting Vref on AD5338R
If I want to use an external reference with the AD5338R, how should I connect this to Vref?  If I tie Vref to the desired reference voltage (5V for example), will I kill the chip?
My fear is that by connecting, a 5V rail straight to the Vref pin, this could cause problems since at startup the internal voltage reference generator is on, and driving Vref at 2.5V.
I could put some resistance between the rail (5V) and Vref (2.5V) but from experience, when the internal reference is off, the voltage at Vref is slightly less than 5V (presumably due to some leakage current? or even just current through the resistor string?).
What is the best way here?
(by the way, i understand that for 5V, I could just leave Vref disconnected and set the GAIN to x2, but I want to know another option)
Thanks!
    on Sep 9, 2016 12:28 AM
    Apologies for the delay.
    The AD5338R has a common reference pin. When using the internal reference, this is the reference output pin. When using an external reference, this is the reference input pin. The default for this pin is as a reference output.
    If you don't want the trouble of having an internal reference, I would suggest you use the AD5338. It is basically the same part without the internal reference.
    Mark
  • Hi Mark,
    No problem, thanks for your response.  I think in future we will probably use chip without internal reference as you suggested.
    Out of interest though, returning to the original question about the AD5338R, what would happen if at startup when the reference pin is in it's default state (of output), it is tied to 5V?  Would this damage the chip?
    Cheers,
    Ollie.
    on Sep 12, 2016 6:42 PM
    Hi Ollie,
    Just to clarify what I meant on my last reply. The AD5338 (without the reference) is the same as the AD5338R in the following aspects:
    • They both use I2C protocol
    • Both are dual channel
    • Both are 10-bit DAC
    They are different in some aspects namely:
    • They use different packages
    • They are not the same die
    • They have different pin-outs
    • They use different software
    • They have different specification parameters
    Apologies if this has caused any confusion.
    To answer your question, there will be a temporary short circuit, the internal die will be heat a little bit, as they try to drive the max current but nothing else, as it will be temporary. This is under the assumption that the reference will be switched from internal to external.
    Mark
  • Hi Mark,
    That answers my question perfectly, thanks!
    Ollie.
