if it is because of some internal circuitry, is it affect affect my signal??. because my signal is highly current and voltage sensitive.
thank you in advance. . . .
Hi Karalan,
We need more details regarding your setup for us to better understand the issue you are encountering.
Can you provide the following information regarding your setup:
Kindly also check the /SHDN is in logic high and the SD bit in the write mode instruction byte is "0" if you are using I2C. When the DACs are in shutdown mode, terminal A is open circuited and wiper W is connected to terminal B. This would cause your resistance value to constantly change since you are measuring an open circuit.
Rainier
Hi Karalan,
Rainier
