Digital Pot Configuration with 3.3V Host Device
I am configuring AD5263 with 3.3V powered Spartan VI FPGA. Schematics as shown:
Since Host device is 3.3V , Vlogic =3.3V (3v3 in schematics)
DigiPot is used for Op-Amp Gain Adjustment and Op-Amp operating on ± 12V.
Vdd = +12V
Vss = -12V
No of Op-Amps = 4 ( All 4 ch. pots used)
Is this configuration correct? Please suggest.
  • Hi ETRX,
    The AD5263 can only be operated at 16.5V single supply or +/-7.5V dual supply ranges. You will be violating the absolute maximum ratings for VSS to ground (-7.5V) and VDD to VSS (16.5V). The easiest solution is to just connect VSS to ground.
    One other concern will be the voltage at A/W/B pins since there are diodes that can be forward biased when used as gain adjustment for the op-amp since the op-amp is supplied with +/-12V. See Figure 54 on the data sheet.
    Thanks and best regards,
    Rainier
