I am using AD8403 for Analog output. I want to get 4 different frequencies analog outputs simultaneously from that IC. Is it possible? please let me know
Thanks and Regards
Thippeswamy H U
Thanks and Regards
Thippeswamy H U
If it is possible please share the examples
Hi Thippeswamy,
Happy New Year!
By analog output do you mean that you want to use it as a DAC?
If so, you can not achieve true simultaneous update of all 4 wiper position. You can try using higher SPI speeds so that it seems like a simultaneous update based on your application. But i am not sure if it will work if your application is a high speed operation.
Koushik
