Incorrect clock configuration AD5700
Hello!
Is it possible to use AD5700 with external clock source 3.6864 MHz to the XTAL 1, when
1) ~XTAL_EN = 0
2) CLK_CFG1 = 1
3) CLK_CFG0 = 1
The device will soon be launched into production, and I don't know whether to urgently fix or leave as is? Prototypes have been successfully tested.
  • Hi TVS,
    If you are using an external 3.686MHz clock source on XTAL1 pin, you need to have the following configuration on these pins:
    1) ~XTAL_EN = 1
    2) CLK_CFG1 = 0
    3) CLK_CFG0 = 0
    You current configuration is using the internal 1.2288MHz crystal oscillator. Kindly see Table 7 on the data sheet for more details. I don't know how were you able to successfully tested your prototypes with the incorrect clock configuration.
    Rainier
