Hai ,Can any one suggest an ic to generate negative reference voltage for AD5545 to get positive o/p voltage from DAC of range 0 to 5V
Hai ,Can any one suggest an ic to generate negative reference voltage for AD5545 to get positive o/p voltage from DAC of range 0 to 5V.
Top Replies
Parents
    on Feb 2, 2018 6:09 AM
    May I know why you choose the AD5545? What is the application for the DAC you are going to use?
    If you only want to get an output of 0-5V, you can use AD5689R which does not need an external amplifier.
    To answer your question, you have two options as we do not currently have a negative reference device:
    1) Use a positive reference in this configuration to create a negative potential on VREF
    2) add another opamp after the transimpedance amplifier to act as an inverter.
    Cheers,
    Ivan
Reply
    Cheers,
    Ivan
Children
No Data
