Hello Community,
I come to you today as I have some trouble reading the ADC value on the AD5593R (I have already managed to get a digital output working).
I have to problems:
- The value of the ADC is varying a lot for a fixed voltage
- I'm trying to set the ADC range select to 2xVref but it seems that I can't get it to work
I am using this schematic:
And this program on a Lopy4 (ESP32) using micropython 1.20 (it's inspired by the figure40 of the datasheet and the AD5593R driver in C):
from machine import I2C import pycom import time import sys from ustruct import unpack from array import array address = 0x11 # 0x11 ADC AD5593_ADC_SEQ_REG = 0b00000010 AD5593_GP_CONTR_REF = 0b00000011 AD5593_ADC_PIN_CONF = 0b00000100 AD5593_GPIO_W_CONF = 0b00001000 AD5593_GPIO_W_WRITE = 0b00001001 AD5593_ADC_READBACK = 0b01000000 AD5593_BLANK = 0b00000000 pycom.heartbeat(False) pycom.rgbled(0x000100) # configure the I2C bus i2c = I2C(0, pins=('P9','P10')) i2c = I2C(0, I2C.MASTER, baudrate=400000) ### ADC/DAC/GPIO Operations : print("Configuring I/O 1 as an ADC input") i2c.writeto(address, bytearray([AD5593_ADC_PIN_CONF,AD5593_BLANK,0b00000010])) i2c.writeto(address, bytearray([AD5593_ADC_SEQ_REG,0b00000010,0b00000010])) i2c.writeto(address, bytearray([AD5593_GP_CONTR_REF,AD5593_BLANK,0b00100000])) #2xVref for the ADC print("General Purpose Control Register Readback :") i2c.writeto(address, bytearray([0b01110011])) print(i2c.readfrom(address,2)) print("Readback ADC") i2c.writeto(address, AD5593_ADC_READBACK) while True: print("Reading ADC I/O 1") data = i2c.readfrom(address,2) value = int(((data[0] & 0x0F) << 8 ) + data[1]) print(value) time.sleep(1)
I have tried reading the General Purpose Control Register before and after writing it with the bit for the ADC range select and I can see that it has been changed (see the difference between the 2 first setup read):
And when I use a potentiometer to have a stable 1.10V on the pin, here is what I get with 100 measurements (1 every second) :
In this configuration 0 is 0V but 4096 is only just below 1.8V.
My first question is: is it normal that the ADC value is varying this much? Is there a way to get something more stable than that without adding averages in the software?
And then, can you tell us what are we doing wrong with the ADC Range select?
Thank you for reading,
Have a good day!
Tristan
Here are some more screenshots of the communication with AD5593R:
Initialization and first readings :
Setting up the General Purpose Register :
Reading a value :
Hi
Are you using an external reference?
Looking at the portion of the code, and the schematic, the only missing link is the reference.
Please measure the reference at Vref. It should be 2.5V.
I'm not using an external reference and haven't look before your message at the power down register... There was no voltage on the Vref pin so as you said, I added this line :
i2c.writeto(address…
i2c.writeto(address, bytearray([AD5593_PWRDWN_REFCON,0b00000010,AD5593_BLANK]))
And it's now working properly. Thank you very much!
