AD5754R applicition question.
I am now using AD5754R, but the VDAC output is always low voltage level.
I have refer to the Demo software, and do just a little modify for the Vout level as below:
//控制寄存器
WriteData1 = 0x1C; //BIT23~BIT16
WriteData2 = 0x00; //BIT15~BIT8
WriteData3 = 0x00; //BIT7 ~ BIT0
WriteToAD5754();
//电源寄存器
WriteData1 = 0x10; //BIT23~BIT16
WriteData3 = 0x1F; //BIT7 ~ BIT0
WriteToAD5754();
//控制电压输出范围
WriteData1 = 0x0C;
WriteData2 = 0x00;
WriteData3 = 0x00;
WriteToAD5754();
 //DAC输出寄存器
 WriteData1 = 0x04;
 WriteData2 = 0x7F;
 WriteData3 = 0x8F;
 WriteToAD5754();
//SPI function
void WriteToAD5754()//(long int WrData)
     unsigned char  i;
     DAC_SPI_SYNC_ON;
   Delay_Us(10);
   DAC_SPI_SYNC_OFF;    //ÖõÍÓÐЧ
   Delay_Us(10);
 //Write out the ControlWord
   for(i=0; i<8; i++)
     DAC_SPI_SCLK_ON;
       Delay_Us(10);
     if(WriteData1&0x80)
      DAC_SPI_SDI_ON;   //Send one to SDI pin
     else
      DAC_SPI_SDI_OFF;   //Send zero to SDI pin
     Delay_Us(10);
     DAC_SPI_SCLK_OFF;
     Delay_Us(10);
     WriteData1 <<= 1;     //Rotate data
     Delay_Us(10);
   for(i=0; i<8; i++)
     DAC_SPI_SCLK_ON;
       Delay_Us(10);
     if(WriteData2&0x80)
     else
     Delay_Us(10);
     DAC_SPI_SCLK_OFF;
     Delay_Us(10);
     WriteData2 <<= 1;     //Rotate data
     Delay_Us(10);
   for(i=0; i<8; i++)
     DAC_SPI_SCLK_ON;
       Delay_Us(10);
     if(WriteData3&0x80)
     else
     Delay_Us(10);
     DAC_SPI_SCLK_OFF;
     Delay_Us(1);
     WriteData3 <<= 1;     //Rotate data
     Delay_Us(10);
   DAC_SPI_SCLK_ON;
 Delay_Us(10);
   //SPI ends
   DAC_SPI_SYNC_ON;
     Delay_Us(10);
void Delay_Us(unsigned int us)
   unsigned int i=0;
   for(i=0;i<us;i++)
    __NOP();
  __NOP();
  __NOP();
  __NOP();
Is there anyone can help me check it, Thanks very much.
