STM32 connect AD5761 but output 0V?
Dear sir:
 Ad5761 used external 2.5V reference voltage, dual channel power supply is 0V and 5V respectively,
chip power supply is 5V, and it is directly connected with STM32f103c8t6 using 3.3V power supply by SPI.
Is there any problem with the schematic?
I debugged the code, but ad5761r output 0V
I don't know what the problem is, please give me some suggestions, thanks!
best regards!
may mail ID:mkkk999@163.com
#include <stdbool.h>
#include <stdint.h>
#include "bsp_ad5761r.h"
#include "stm32f10x.h"
#include "stm32f10x_conf.h"
#include "spi.h"
#define false 0
#define true  1
#define AD5761R_RESET_PIN       GPIO_Pin_9  	//PB9
#define AD5761R_CLEAR_PIN       GPIO_Pin_8  	//PB8
//低电平有效数字接口同步输入引脚。这是输入数据的帧同步信号。
//当SYNC为低电平时,使能输入移位寄存器,然后数据在后续时钟的下降沿输入移位寄存器。输入移位寄存器在SYNC的上升沿更新。
#define AD5761R_SYNC_PIN        GPIO_Pin_4  	//PA4
//低电平有效加载DAC逻辑输入引脚。用于更新DAC寄存器和模拟输出。
//当永久接为低电平时,DAC输出会在SYNC上升沿更新。LDAC引脚不能悬空。
#define AD5761R_LDAC_PIN        GPIO_Pin_10 	//PB10
#define AD5761R_RCC_GPIOClockCmd() RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE)
#define PIN_OUT(g,p,v)			(v) ? GPIO_SetBits(g, p) : GPIO_ResetBits(g, p)
#define PIN_IN(g,p)				GPIO_ReadInputDataBit(g, p)
#define AD5761R_CLEAR(x)        PIN_OUT(GPIOB, AD5761R_CLEAR_PIN, x)
#define AD5761R_RESET(x)        PIN_OUT(GPIOB, AD5761R_RESET_PIN, x)
#define AD5761R_SYNC(x)   		PIN_OUT(GPIOA, AD5761R_SYNC_PIN, x)
#define AD5761R_LDAC(x)         PIN_OUT(GPIOB, AD5761R_LDAC_PIN, x)
void SPI1_init(void)
	SPI_InitTypeDef  SPI_InitStructure;
	GPIO_InitTypeDef GPIO_InitStructure;
	RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );
	RCC_APB2PeriphClockCmd ( RCC_APB2Periph_SPI1, ENABLE ); // SPI_Periph clock enable--72MHZ
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_SetBits(GPIOA, GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7);//pull up
	// SPI1 configuration
	SPI_InitStructure.SPI_Direction 				= SPI_Direction_2Lines_FullDuplex;
	SPI_InitStructure.SPI_Mode 						= SPI_Mode_Master;
	SPI_InitStructure.SPI_DataSize 					= SPI_DataSize_8b;
	SPI_InitStructure.SPI_CPOL 							= SPI_CPOL_High;
	SPI_InitStructure.SPI_CPHA 							= SPI_CPHA_1Edge;
	SPI_InitStructure.SPI_NSS 							= SPI_NSS_Soft;
	SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
	SPI_InitStructure.SPI_FirstBit 					= SPI_FirstBit_MSB;
	SPI_InitStructure.SPI_CRCPolynomial 		= 7;
	SPI_Init(SPI1 , &SPI_InitStructure);
	SPI_Cmd(SPI1 , ENABLE);
uint8_t SPI1_ReadWriteByte(uint8_t TxData)
	uint8_t retry = 0;
	while (SPI_I2S_GetFlagStatus(SPI1 , SPI_I2S_FLAG_TXE) == RESET)
		 retry++;
         if(retry > 200)return 0;
	SPI_I2S_SendData(SPI1,TxData);
	retry=0;
	while (SPI_I2S_GetFlagStatus(SPI1 , SPI_I2S_FLAG_RXNE) == RESET)
 		retry++;
	return SPI_I2S_ReceiveData(SPI1);
void SPI1_SetSpeed(uint8_t SPI_BaudRatePrescaler)
    assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler));
    SPI1->CR1&=0XFFC7;
    SPI1->CR1|=SPI_BaudRatePrescaler;
    SPI_Cmd(SPI1,ENABLE);
//72M
#define delay_us(x) { unsigned int _dcnt; \
_dcnt=(x*160); \
while(_dcnt-- > 0) \
{ continue; }\
void delay_ms(u16 time)
   u16 i=0;
   while(time--)
      i=4000;
      while(i--) ;
/************************ Functions Definitions *******************************/
static uint8_t gpio_set_value( uint8_t gpio_pin,uint8_t value);
static int32_t  spi_write_and_read( uint8_t spi_ss, uint8_t *data,uint8_t number);
static void AD5761R_GPIO_Init(void);
//static ad5761r_dev * device_glb;
 * SPI write to device.
 * @param dev - The device structure.
 * @param reg_addr_cmd - The input shift register command.
 * 						 Accepted values: CMD_NOP
 * 										  CMD_WR_TO_INPUT_REG
 * 										  CMD_UPDATE_DAC_REG_FROM_INPUT_REG
 * 										  CMD_WR_UPDATE_DAC_REG
 * 										  CMD_WR_CTRL_REG
 * 										  CMD_SW_DATA_RESET
 * 										  CMD_DIS_DAISY_CHAIN
 * 										  CMD_RD_INPUT_REG
 * 										  CMD_RD_DAC_REG
 * 										  CMD_RD_CTRL_REG
 * 										  CMD_SW_FULL_RESET
 * @param reg_data - The transmitted data.
 * @return 0 in case of success, negative error code otherwise.
int32_t ad5761r_write(ad5761r_dev *dev,
											uint8_t reg_addr_cmd,
											uint16_t reg_data)
	uint8_t data[3];
	int32_t ret;
	data[0] = reg_addr_cmd;
	data[1] = (reg_data & 0xFF00) >> 8;
	data[2] = (reg_data & 0x00FF) >> 0;
	AD5761R_SYNC(0);
	ret = spi_write_and_read(dev->spi_ss, data, 3);
	AD5761R_SYNC(1);
	return ret;
 *  SPI read from device.
 * 										  CMD_WR_CTRL_REG
 * 										  CMD_SW_DATA_RESET
 * 										  CMD_RD_INPUT_REG
 * 										  CMD_RD_DAC_REG
 * 										  CMD_RD_CTRL_REG
 * 										  CMD_SW_FULL_RESET
 * @param - The received data.
int32_t ad5761r_read(ad5761r_dev *dev,
					 uint16_t *reg_data)
    uint8_t data[3];
    int32_t ret = 0;
	data[1] = 0;
	data[2] = 0;
	AD5761R_SYNC(0);
	*reg_data = (data[1] << 8) | data[2];
	AD5761R_SYNC(1);
	return ret;
 * Readback the register data.
 * Note: Readback operation is not enabled if daisy-chain mode is disabled.
 * @param reg - The register to be read.
 * 				Accepted values: AD5761R_REG_INPUT
 * 								 AD5761R_REG_DAC
 * 								 AD5761R_REG_CTRL
 * @param reg_data - The register data.
int32_t ad5761r_register_readback(ad5761r_dev *dev,
								  ad5761r_reg reg,
								  uint16_t *reg_data)
	uint8_t reg_addr;
	int32_t ret;
	if (!dev->daisy_chain_en) {
		return -1;
	switch (reg) {
	case AD5761R_REG_INPUT:
		reg_addr = CMD_RD_INPUT_REG;
		break;
	case AD5761R_REG_DAC:
		reg_addr = CMD_RD_DAC_REG;
		break;
	case AD5761R_REG_CTRL:
		reg_addr = CMD_RD_CTRL_REG;
		break;
	default:
		return -1;
	/* During the first command, the last 16 bits are don?t care bits. */
	ret = ad5761r_read(dev, reg_addr, reg_data);
	/* During the next command, the register contents are shifted out of the
	   SDO pin with the MSB shifted out first. */
	ret |= ad5761r_read(dev, reg_addr, reg_data);
	return ret;
 * Configure the part based on the settings stored in the device structure.
int32_t ad5761r_config(ad5761r_dev *dev)
	uint16_t reg_data;
	reg_data = AD5761R_CTRL_CV(dev->cv) |
			   (dev->ovr_en ? AD5761R_CTRL_OVR : 0) |
			   (dev->b2c_range_en? AD5761R_CTRL_B2C : 0) |
			   (dev->exc_temp_sd_en ? AD5761R_CTRL_ETS : 0) |
			   (dev->int_ref_en ? 0 : AD5761R_CTRL_IRO) |
			   AD5761R_CTRL_PV(dev->pv) |
			   AD5761R_CTRL_RA(dev->ra);
	return ad5761r_write(dev, CMD_WR_CTRL_REG, reg_data);
 * Enable/disable daisy-chain mode.
 * @param en_dis - Set true in order to enable the daisy-chain mode.
 * 				   Accepted values: true
 * 									false
int32_t ad5761r_set_daisy_chain_en_dis(ad5761r_dev *dev,
									   Bool en_dis)
	dev->daisy_chain_en = en_dis;
	return ad5761r_write(dev, CMD_DIS_DAISY_CHAIN,
			AD5761R_DIS_DAISY_CHAIN_DDC(!en_dis));
 * Get the status of the daisy-chain mode.
 * @param en_dis - The status of the daisy-chain mode (enabled, disabled).
int32_t ad5761r_get_daisy_chain_en_dis(ad5761r_dev *dev,
									   Bool *en_dis)
	*en_dis = dev->daisy_chain_en;
	return 0;
 * Set the output_range.
 * @param out_range - The output range.
 * 					  Accepted values: AD5761R_RANGE_M_10V_TO_P_10V,
 * 									   AD5761R_RANGE_0_V_TO_P_10V
 * 									   AD5761R_RANGE_M_5V_TO_P_5V
 * 									   AD5761R_RANGE_0V_TO_P_5V
 * 									   AD5761R_RANGE_M_2V5_TO_P_7V5
 * 									   AD5761R_RANGE_M_3V_TO_P_3V
 * 									   AD5761R_RANGE_0V_TO_P_16V
 * 									   AD5761R_RANGE_0V_TO_P_20V
int32_t ad5761r_set_output_range(ad5761r_dev *dev,
								 ad5761r_range out_range)
	dev->ra = out_range;
	return ad5761r_config(dev);
 * Get the output_range.
int32_t ad5761r_get_output_range(ad5761r_dev *dev,
								 ad5761r_range *out_range)
	*out_range = dev->ra;
	return 0;
 * Set the power up voltage.
 * @param pv - The power up voltage.
 * 			   Accepted values: AD5761R_SCALE_ZERO
 *								AD5761R_SCALE_HALF
 *								AD5761R_SCALE_FULL
int32_t ad5761r_set_power_up_voltage(ad5761r_dev *dev,
									 ad5761r_scale pv)
	dev->pv = pv;
 * Get the power up voltage.
int32_t ad5761r_get_power_up_voltage(ad5761r_dev *dev,
									 ad5761r_scale *pv)
	*pv = dev->pv;
	return 0;
 * Set the clear voltage.
 * @param cv - The clear voltage.
int32_t ad5761r_set_clear_voltage(ad5761r_dev *dev,
								  ad5761r_scale cv)
	dev->cv = cv;
 * Get the clear voltage.
int32_t ad5761r_get_clear_voltage(ad5761r_dev *dev,
								  ad5761r_scale *cv)
	*cv = dev->cv;
	return 0;
 * Enable/disable internal reference.
 * @param en_dis - Set true in order to enable the internal reference.
 * 									false
int32_t ad5761r_set_internal_reference_en_dis(ad5761r_dev *dev,
											  Bool en_dis)
	dev->int_ref_en = en_dis;
 * Get the status of the internal reference.
 * @param en_dis - The status of the internal reference (enabled, disabled).
int32_t ad5761r_get_internal_reference_en_dis(ad5761r_dev *dev,
											  Bool *en_dis)
	*en_dis = dev->int_ref_en;
	return 0;
 * Enable/disable ETS (exceed temperature shutdown) function.
 * @param en_dis - Set true in order to enable the ETS function.
 * 									false
int32_t ad5761r_set_exceed_temp_shutdown_en_dis(ad5761r_dev *dev,
												Bool en_dis)
	dev->exc_temp_sd_en = en_dis;
 * Get the status of the ETS (exceed temperature shutdown) function.
 * @param en_dis - The status of the ETS function (enabled, disabled).
int32_t ad5761r_get_exceed_temp_shutdown_en_dis(ad5761r_dev *dev,
												Bool *en_dis)
	*en_dis = dev->exc_temp_sd_en;
	return 0;
 * Enable/disable the twos complement bipolar output range.
 * @param en_dis - Set true in order to enable the twos complement bipolar
 * 				   output range.
 * 									false
int32_t ad5761r_set_2c_bipolar_range_en_dis(ad5761r_dev *dev,
											Bool en_dis)
	dev->b2c_range_en = en_dis;
 * Get the status of the twos complement bipolar output range.
 * @param en_dis - The status of the twos complement bipolar output range
 * 				   (enabled, disabled).
int32_t ad5761r_get_2c_bipolar_range_en_dis(ad5761r_dev *dev,
											Bool *en_dis)
	*en_dis = dev->b2c_range_en;
	return 0;
 * Enable/disable the 5% overrange.
 * @param en_dis - Set true in order to enable the 5% overrange.
 * 									false
int32_t ad5761r_set_overrange_en_dis(ad5761r_dev *dev,
									 Bool en_dis)
	dev->ovr_en = en_dis;
 * Get the status of the 5% overrange.
 * @param en_dis - The status of the twos 5% overrange (enabled, disabled).
int32_t ad5761r_get_overrange_en_dis(ad5761r_dev *dev,
									 Bool *en_dis)
	*en_dis = dev->ovr_en;
	return 0;
 * Get the short-circuit condition.
 * Note: The condition is reset at every control register write.
 * @param en_dis - The status of the short-circuit condition (detected,
 * 				   not detected).
int32_t ad5761r_get_short_circuit_condition(ad5761r_dev *dev,
											Bool *sc)
	uint16_t reg_data;
	int32_t ret;
	ret = ad5761r_read(dev, CMD_RD_CTRL_REG, &reg_data);
	*sc = ((reg_data & AD5761R_CTRL_SC) >> 12);
	return ret;
 * Get the brownout condition.
 * @param en_dis - The status of the brownout condition (detected,
 * 				   not detected).
int32_t ad5761r_get_brownout_condition(ad5761r_dev *dev,
									   Bool *bo)
	uint16_t reg_data;
	int32_t ret;
	*bo = ((reg_data & AD5761R_CTRL_BO) >> 11);
	return ret;
 * Set the reset pin value.
 * @param value - The pin value.
 * 				  Accepted values: GPIO_LOW
 * 				  				   GPIO_HIGH
int32_t ad5761r_set_reset_pin(ad5761r_dev *dev,
							  uint8_t value)
	//if (dev->gpio_reset >= 0) {
		dev->gpio_reset_value = value;
		return gpio_set_value(dev->gpio_reset, dev->gpio_reset_value);
	//} else
	//	return -1;
 * Get the reset pin value.
int32_t ad5761r_get_reset_pin(ad5761r_dev *dev,
							  uint8_t *value)
		*value = dev->gpio_reset_value;
		return 0;
	//} else
	//	return -1;
 * Set the clr pin value.
 * 				  				   GPIO_HIGH
int32_t ad5761r_set_clr_pin(ad5761r_dev *dev,
							uint8_t value)
	//if (dev->gpio_clr >= 0) {
		dev->gpio_clr_value = value;
		return gpio_set_value(dev->gpio_clr, dev->gpio_clr_value);
	//} else
	//	return -1;
 * Get the clr pin value.
int32_t ad5761r_get_clr_pin(ad5761r_dev *dev,
							uint8_t *value)
		*value = dev->gpio_clr_value;
		return 0;
	//} else
	//	return -1;
 * Set the ldac pin value.
 * 				  				   GPIO_HIGH
int32_t ad5761r_set_ldac_pin(ad5761r_dev *dev,
							 uint8_t value)
	//if (dev->gpio_ldac >= 0) {
		dev->gpio_ldac_value = value;
		return gpio_set_value(dev->gpio_ldac, dev->gpio_ldac_value);
	//} else
	//	return -1;
 * Get the ldac pin value.
int32_t ad5761r_get_ldac_pin(ad5761r_dev *dev,
							 uint8_t *value)
		*value = dev->gpio_ldac_value;
		return 0;
	//} else
	//	return -1;
 * Write to input register.
 * @param dac_data - The DAC data.
int32_t ad5761r_write_input_register(ad5761r_dev *dev,
									 uint16_t dac_data)
	uint16_t reg_data;
		reg_data = AD5761R_DATA(dac_data);
	return ad5761r_write(dev, CMD_WR_TO_INPUT_REG, reg_data);
 * Update DAC register.
int32_t ad5761r_update_dac_register(ad5761r_dev *dev)
	return ad5761r_write(dev, CMD_UPDATE_DAC_REG, 0);
 * Write to input register and update DAC register.
 * @param dac_data - The register data.
int32_t ad5761r_write_update_dac_register(ad5761r_dev *dev,
										  uint16_t dac_data)
	uint16_t reg_data;
  	AD5761R_LDAC(1);
	ad5761r_write(dev, CMD_WR_UPDATE_DAC_REG, reg_data);
	return 0;
 * Software data reset.
int32_t ad5761r_software_data_reset(ad5761r_dev *dev)
	return ad5761r_write(dev, CMD_SW_DATA_RESET, 0);
 * Software full reset.
int32_t ad5761r_software_full_reset(ad5761r_dev *dev)
	return ad5761r_write(dev, CMD_SW_FULL_RESET, 0);
 * Initialize the device.
 * @param device - The device structure.
 * @param init_param - The structure that contains the device initial
 * 					   parameters.
int32_t ad5761r_init(void)
	return 0;
 * SCK空闲时刻为高电平 技术边沿被采样 =>CPOL = 1 CPHA = 0
 * SCLK下降沿输入,SYNC上升沿锁存
	for(uint8_t i=0; i<number; i++){
		*(data+i) = SPI1_ReadWriteByte(*(data+i));
    return 0;
	AD5761R_RCC_GPIOClockCmd();
	GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
	GPIO_InitStructure.GPIO_Pin = AD5761R_SYNC_PIN;
	GPIO_Init(GPIOA,&GPIO_InitStructure);
	AD5761R_SYNC(1);
	GPIO_InitStructure.GPIO_Pin = AD5761R_CLEAR_PIN|AD5761R_RESET_PIN|AD5761R_LDAC_PIN;
	GPIO_Init(GPIOB,&GPIO_InitStructure);
	AD5761R_CLEAR(1);
	AD5761R_RESET(1);
	AD5761R_LDAC(0);
	SPI1_init();
	SPI1_SetSpeed(SPI_BaudRatePrescaler_256);
static uint8_t gpio_set_value( uint8_t gpio_pin,uint8_t value)   //没有用到
	 return 0;
/***********AD5761R的初始化*******************/
void AD5761R_Init(void)
	AD5761R_GPIO_Init();
	AD5761R_RESET(0);
  	ad5761r_dev dev;
	dev.ra  = AD5761R_RANGE_0V_TO_P_5V;   //output volt range
	dev.int_ref_en = true;                //open ref volt
	dev.cv = AD5761R_SCALE_ZERO;  //clear voltage
	dev.b2c_range_en = false;
	dev.pv = AD5761R_SCALE_ZERO;  //power up voltage
	dev.ovr_en = false;
	dev.daisy_chain_en = true;
	dev.exc_temp_sd_en = false;
	AD5761R_RESET(1);
	//ad5761r_software_full_reset(&dev);
	ad5761r_config(&dev);
	ad5761r_write_update_dac_register(0,0);
/*************set AD5761R output volt   0-NV ************************/
void AD5761R_SetVoltage(float volt)
	uint16_t reg_val;
	if(volt > 5.0){
		volt = 5.0;
	}else if(volt < 0){
		volt = 0.0;
	double dval = volt;
	//dval = volt * 6553.6;=>volt * 65536/10
	dval = volt * 65536/5;
    reg_val = dval;
	ad5761r_write_update_dac_register(0,reg_val);
