How to estimate LTC2757 output voltage noise density?
I am trying to figure out how to estimate the total output noise voltage density when I connect a LT1460 reference, LTC2757 DAC, and a LT1468 output transimpedance amplifier together. The datasheet simply lists "output voltage noise density" with no information about how this is measured (although note 11 seems to indicate this is simply the johnson noise of some resistor).
I know how to calculate the noise of a TIA but I don't know how the DAC converts the reference voltage noise into output current noise. Can you explain?
Many thanks!
Made a mistake.
[edited by: justinis at 1:59 PM (GMT 0) on 17 Jun 2019]
