AD5422 not working
I'm trying to get an AD5422 working. I can't get an output signal or register data from a readback.
 Here it the schematics I use:
DVcc = 3.36V, AVdd = 11,93V, AVss = 0V, Clear = 0V;
Vout stays always about 16mV.
  1. I removed IC13, R57 and T11 an connected Vout with +Vsense. Same problem.
  2. I changed the AD5422. No change.
Here the plots from the SPI-bus.
Yellow = Latch, Blue = CLK, Purple = SDI, Green = SDO
 Reset:
Set config (Rext = on, 0-5 Range, Enable output):
 Set data value:
Readback config-reg:
 I can't figure out, what is wrong.
Can someone pleas assist me?
Regards
 Sephan
