Issues in Cyclic Voltammetry results using Analog example
Product Number: AD5940
We are experiencing issues with results in cyclic voltammetry with EVAL-AD5940ELCZ using example project. We use a 5 mM potassium ferrocyanide in 0.1 M KCl solution. Settings: VZERO = 1000, RampStartVolt = -800 RampPeakVolt = 800.
Output response with these parameters:
We have made a cyclic voltametry to same electrode and solution with a commercial potentiostat:
We don´t show similar results although we have varied different parameters in the example.
It is not the same ramp duration. As we use -800 to 800 and the potentostat uses -800 to 1200. But we have found problems when using a voltage over 1.8V in VRE (red line in oscilloscope) as it gets a near 3.24V in VCE (green line) which saturates.
After trying with different VZERO and ramps, best results have been obtained with VZERO = 1000 and ramp -800 to 800. This corresponds with above output response figure.
I would be grateful for your assistance in this matter.
