Strong EMC design
AD7124-4
Recommended for New Designs
The AD7124-4 is a low power, low noise, completely integrated analog front end for high precision measurement applications. The device contains a low noise...
Datasheet
AD7124-4 on Analog.com
Hi Tomsik ,
Enabling the input buffers is the recommended solution for your case.
In unbuffered mode at gain = 1, the ADC input directly drives the modulator sampling capacitor. The datasheet/FAQ explicitly note that with an RC filter in this mode, if the RC time constant is too large, the sampling capacitor cannot fully charge, and gain errors result; therefore, R and C must be limited in unbuffered mode. This matches your observation that reducing the series resistance from 1 kΩ to 1 Ω removed most of the error.
With the input buffers enabled, the input channel sees the high-impedance buffer input, so significant source impedance and larger RC values can be tolerated without introducing gain error.
The main trade-off when enabling the buffers at gain = 1 is reduced input voltage headroom: in buffered mode at gain = 1, the absolute AIN range is limited to AVSS + 100 mV to AVDD − 100 mV, whereas in unbuffered mode at gain = 1 it is AVSS − 50 mV to AVDD + 50 mV. The provided sources do not quantify any additional gain or offset error from enabling the buffers beyond this headroom constraint.
Francis
