I'm using the AD7994 ADC in Mode 2 operation (Command mode - specified on P.29-30 of the Datasheet). From my understanding of this operation, the device powers up and begins converting the lowest selected channel on the "fifth SCL falling edge of the address point byte". This point is shown on the timing diagram for the single channel read (fig 33) and is marked by point A. I assume this same point is used for the first read of a multi-channel read, but I am unsure when in the I2C timings the samples for the other channels are taken.
The datasheet says "The first read accesses the data from the conversion on VIN1. While this read takes place, a conversion occurs on VIN2. The second read accesses this data from VIN2.", but this is too vague. I am using I2C fast mode, so the SCL is cycling at 400kHz. A read takes 18 bits (2 data bytes and 2 ACKs), which leaves a window of 45us. I am measuring UK mains signals (50Hz), so at the extreme, this introduces around a 1 degree phase uncertainty.
Is there any further information on the exact point in the I2C timing where the samples for the other channels occurs?
I have ran a few experiments to try and determine this, but my current set up is not accurate enough. I tried connecting all the inputs together to get an identical signal on each input, and observing the phase offset between each waveform to show the offset in sampling times. I then ran the captured waveforms through curve fitting to determine the phase difference between the waveforms, but this proved too unreliable as I am passing the signals through the wider circuitry of my device, and not interfacing directly with the ADC as I do not have a breakout board for the device. The added circuitry added too much noise and unreliability, so accurate data was not captured.
