Peak Current of Input Pin
The user inquired about the AD4112's current input pin limits, specifically if the ±50 mA maximum is continuous. The final answer clarifies that ±50 mA is an absolute maximum rating for brief fault tolerance only, not for continuous operation. Continuous current should be within the input current range, which is significantly lower. External current limiting is recommended for sustained or repeated currents near the ±50 mA limit.
Product Number: AD4112
For AD4112, as per datasheet, each current input pin can handle max of +-50mA. Is this continuous current?
What is the peak current that each pin can handle and for what duration?
Thanks.
