Hi everyone,
I’m working on a ratiometric measurement setup using the AD7124-8 ADC and a Wheatstone bridge–based pressure sensor MPM281PT (such as piezoresistive pressure transducer).
I’m looking for an example or detailed explanation covering the following:
Wiring diagram for connecting the full-bridge pressure sensor to the AD7124-8 in a ratiometric configuration.
Recommended ADC configuration (differential input mode, gain, reference selection, filter settings, and sample rate).
How to convert the ADC output code to actual pressure values (in bar, kPa, or psi) — including the formula and any calibration steps.
Example code (C/C++ or Python) to read data from the AD7124-8 and compute the pressure based on the ratiometric principle.
My goal is to achieve a stable and precise pressure measurement by using the excitation voltage as the reference, thereby compensating for supply voltage variations.
If anyone has shared schematics, register configurations, or sample code for a similar ratiometric setup, I’d really appreciate your guidance!
Thanks in advance!
