Indefinite capture using EVAL-AD7606C16FMCZ (and SDP-H1)
The user is seeking advice on capturing data indefinitely from the EVAL-AD7606C16FMCZ ADC using the SDP-H1 and ACE software. The final answer suggests optimizing ACE settings for reduced data gaps, such as disabling session file export, using append mode, and binary format. For continuous high-throughput capture, the SDP-K1 with no-OS drivers is recommended, supporting all channels at up to 200 ksps. The accompanying answer notes that the Mbed example link provided is dead.
Product Number: AD7606C-16
Hi, I have EVAL-AD7606C16FMCZ and an SDP-H1 to capture from the ADC into the ACE software. However, ACE cannot perform indefinite capture and workarounds produce small gaps in the data. I was wondering if anyone has any advice on using the evaluation board (with or without the SDP) to capture indefinitely? I have tried to read the no-OS documentation but am new to this world so don't understand it to an adequate level.
The application is relatively crude with the key constraints being a sample rate of above 50 ksps (although the higher the better) and access to all channels. The data doesn't need to be realtime (although that would be a nice bonus). Does anybody have any guidance beyond what is in the no-OS documentation?
  • Hi
    You're absolutely right — the ACE software, while user-friendly and great for initial evaluation, is not intended for seamless, indefinite data capture. Even with scripting workarounds like DataCaptureToFile or AsyncRawCaptureToFile, users often encounter 10–20% data gaps due to file I/O and session metadata overhead.
    If you're using ACE with SDP-H1:
    You can reduce data loss with the following optimized settings for AsyncRawCaptureToFile:
    • ExportSessionFile = false → skips writing session metadata
    • MergeMode = "Append" → continuously writes to the same file
    • Use binary format instead of CSV → improves write speed significantly
    Additionally, remote scripting is supported via MATLAB and Python.
    Refer to this useful guide:
     How to Quickly Evaluate Data Converters Using ACE with Python or MATLAB | Analog Devices
    Even with these optimizations, ~0.12s data gaps are typical — this appears to be the practical limit with ACE.
    For true continuous/high-throughput capture:
     1: SDP-K1 + No-OS Drivers
    The SDP-K1 platform is better suited for indefinite capture using ADI’s no-OS drivers, offering:
    • Continuous data streaming via SPI or parallel interface
    • Capture of all channels at up to 200 ksps
    • Flexibility to implement your own buffering and logging solution
    Resources:
    • AD7606 IIO Application Wiki
      Includes:
      • Hardware setup
      • Jumper settings (VIO_ADJUST → 3.3V)
      • Firmware flashing via Mbed Online Compiler
      • Streaming to IIO Oscilloscope
    • AD7606C-16 Driver Page – ADI Developer Portal
    • AD7606 No-OS Driver on GitHub
    • EVAL-AD7606 Mbed Example
    2: FPGA Platform (e.g., ZedBoard)
    Some users have integrated the AD7606C-16 with ZedBoard + HDL + no-OS drivers, enabling:
    Support for the ZedBoard path is currently limited, as we're still working on this internally.
    Hope this helps.
    Red
  • Hi Red,
    Thanks for getting back to me with your helpful comments. This Mbed example link is dead, do you have an alternative?
    Thanks
