ADAS3022 not working
Product Number: ADAS3022
I have an EVAL-ADAS3022 with the FPGA in reset and powered using a bench power supply (no connection to a EVAL-CED1Z). My bus controller is connected to the ADAS3022 running the following code (XJEase) which I expect to yield 0x7FFF but instead yields differend results, can anyone see what I am doing wrong?
  • -- CODE --
    LOCAL ReadCycle()(INT readData)
    //CONST INT SPI_CPOL := 0; // 0 or 1 - the stable/starting state of SCLK
    //CONST INT SPI_CPHA := 1; // 0 (sample SDOUT on 1st SCLK edge) or 1 (sample on 2nd SCLK edge)
    //CONST INT CFG_DEF_VAL := 0xF7FF;
    INT i, j, writeData;
    SPI_SetSampleBeforeClockEdge(FALSE)();
    writeData := CFG_DEF_VAL;
    FOR j := 0 TO 1
    SET PIO.TEST_PIO := j[0];
    PRINT("TEST PIO - ", j[0], "\n");
    SET PD := 0, CNV := 0, RESET := 0;
    SET PD := 1;
    NANO_SLEEP(1000);
    SET PD := 0;
    NANO_SLEEP(100 * 1000 * 1000);
    SET RESET := 1;
    NANO_SLEEP(1000);
    SET RESET := 0;
    SLEEP(100);
    SPI_Initialise()();
    ToggleConversion()();
    SET nCS := 0;
    SPI_ReadWriteSerial(16, 0)(readData);
    SET nCS := 1;
    PRINT("read - 0b", BIN(readData[15..0]), " - 0x", HEX(readData[15..0]), "\n");
    SET nCS := 0;
    SET nCS := 1;
    SET nCS := 0;
    SET nCS := 1;
    SET nCS := 0;
    SPI_ReadWriteSerial(16, writeData)(readData);
    SET nCS := 1;
    SET nCS := 0;
    SET nCS := 1;
    SET nCS := 0;
    SET nCS := 1;
    END;
    END;
    LOCAL ToggleConversion()()
    INT i;
    NANO_SLEEP(1000); // instead of polling busy
    SET CNV := 0;
    NANO_SLEEP(20);
    SET CNV := 1;
    NANO_SLEEP(20);
    SET CNV := 0;
    NANO_SLEEP(1500); // instead of polling busy
    END;
    -- RESULTS 1 --
    read - 0b1111110001100101 - 0xFC65
    read - 0b1000111111001111 - 0x8FCF
    read - 0b0000111111001111 - 0xFCF
    -- RESULTS 2 --
    read - 0b1111110001011100 - 0xFC5C
    read - 0b1111110001011011 - 0xFC5B
    The results seem to have some pattern
  • Hi,  .
    We'll look into this and get back to you.
    Jo
