does anyone have experience installing the device driver from the AD4000 on the Raspberry Pi 5 under the operating system Debian 12.
Device diver:
https://github.com/analogdevicesinc/linux/blob/main/drivers/iio/adc/ad4000.c
When I try to compile the driver, I get a lot of error messages.
pi@raspberrypi:~/Desktop/Neu $ make
make -C /usr/lib/modules/6.6.74+rpt-rpi-2712/build M=/home/pi/Desktop/Neu modules
make[1]: Verzeichnis „/usr/src/linux-headers-6.6.74+rpt-rpi-2712“ wird betreten
CC [M] /home/pi/Desktop/Neu/ad4000.o
In file included from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:228,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:11,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/ptrace.h:11,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/irqflags.h:10,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/irqflags.h:17,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/rcupdate.h:26,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/rculist.h:11,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/pid.h:5,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/sched.h:14,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/ratelimit.h:6,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/dev_printk.h:16,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/device.h:15,
from /home/pi/Desktop/Neu/ad4000.c:11:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h: In function ‘read_cpuid_cachetype’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:230:55: error: ‘SYS_CTR_EL0’ undeclared (first use in this function); did you mean ‘SYS_TCR_EL1’?
230 | #define read_cpuid(reg) read_sysreg_s(SYS_ ## reg)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/sysreg.h:1077:46: note: in definition of macro ‘read_sysreg_s’
1077 | u32 __maybe_unused __check_r = (u32)(r); \
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:309:16: note: in expansion of macro ‘read_cpuid’
309 | return read_cpuid(CTR_EL0);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:230:55: note: each undeclared identifier is reported only once for each function it appears in
In file included from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/math.h:6,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/kernel.h:26,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:25:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/div64.h: In function ‘__div64_32’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/div64.h:30:17: error: expected string literal before ‘__asmeq’
30 | asm( __asmeq("%0", "r0")
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/div64.h:26:31: warning: unused variable ‘__base’ [-Wunused-variable]
26 | register unsigned int __base asm("r4") = base;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_capabilities_finalized’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:443:43: error: ‘ARM64_ALWAYS_SYSTEM’ undeclared (first use in this function)
443 | return alternative_has_cap_likely(ARM64_ALWAYS_SYSTEM);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘cpuid_feature_cap_perfmon_field’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:546:20: error: ‘ID_AA64DFR0_EL1_PMUVer_IMP_DEF’ undeclared (first use in this function)
546 | if (val == ID_AA64DFR0_EL1_PMUVer_IMP_DEF)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64mmfr0_mixed_endian_el0’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:590:60: error: ‘ID_AA64MMFR0_EL1_BIGEND_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
590 | return cpuid_feature_extract_unsigned_field(mmfr0, ID_AA64MMFR0_EL1_BIGEND_SHIFT) == 0x1 ||
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:591:61: error: ‘ID_AA64MMFR0_EL1_BIGENDEL0_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
591 | cpuid_feature_extract_unsigned_field(mmfr0, ID_AA64MMFR0_EL1_BIGENDEL0_SHIFT) == 0x1;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64pfr0_32bit_el1’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:596:62: error: ‘ID_AA64PFR0_EL1_EL1_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
596 | u32 val = cpuid_feature_extract_unsigned_field(pfr0, ID_AA64PFR0_EL1_EL1_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64pfr0_32bit_el0’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:603:62: error: ‘ID_AA64PFR0_EL1_EL0_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
603 | u32 val = cpuid_feature_extract_unsigned_field(pfr0, ID_AA64PFR0_EL1_EL0_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64pfr0_sve’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:610:62: error: ‘ID_AA64PFR0_EL1_SVE_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
610 | u32 val = cpuid_feature_extract_unsigned_field(pfr0, ID_AA64PFR0_EL1_SVE_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64pfr1_sme’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:617:62: error: ‘ID_AA64PFR1_EL1_SME_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
617 | u32 val = cpuid_feature_extract_unsigned_field(pfr1, ID_AA64PFR1_EL1_SME_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64pfr1_mte’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:624:62: error: ‘ID_AA64PFR1_EL1_MTE_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
624 | u32 val = cpuid_feature_extract_unsigned_field(pfr1, ID_AA64PFR1_EL1_MTE_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:626:23: error: ‘ID_AA64PFR1_EL1_MTE_MTE2’ undeclared (first use in this function)
626 | return val >= ID_AA64PFR1_EL1_MTE_MTE2;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘cpu_supports_mixed_endian_el0’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:230:55: error: ‘SYS_ID_AA64MMFR0_EL1’ undeclared (first use in this function)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:637:46: note: in expansion of macro ‘read_cpuid’
637 | return id_aa64mmfr0_mixed_endian_el0(read_cpuid(ID_AA64MMFR0_EL1));
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘supports_csv2p3’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:647:38: error: ‘SYS_ID_AA64PFR0_EL1’ undeclared (first use in this function); did you mean ‘SYS_ICC_AP1R0_EL1’?
647 | pfr0 = read_sysreg_s(SYS_ID_AA64PFR0_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:652:57: error: ‘ID_AA64PFR0_EL1_CSV2_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
652 | ID_AA64PFR0_EL1_CSV2_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘supports_clearbhb’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:661:39: error: ‘SYS_ID_AA64ISAR2_EL1’ undeclared (first use in this function)
661 | isar2 = read_sysreg_s(SYS_ID_AA64ISAR2_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:666:53: error: ‘ID_AA64ISAR2_EL1_CLRBHB_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
666 | ID_AA64ISAR2_EL1_CLRBHB_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_32bit_el0’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:674:43: error: ‘SYS_ID_AA64PFR0_EL1’ undeclared (first use in this function); did you mean ‘SYS_ICC_AP1R0_EL1’?
674 | u64 pfr0 = read_sanitised_ftr_reg(SYS_ID_AA64PFR0_EL1);
| SYS_ICC_AP1R0_EL1
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_4kb_granule’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:685:40: error: ‘SYS_ID_AA64MMFR0_EL1’ undeclared (first use in this function)
685 | mmfr0 = read_sanitised_ftr_reg(SYS_ID_AA64MMFR0_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:687:49: error: ‘ID_AA64MMFR0_EL1_TGRAN4_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
687 | ID_AA64MMFR0_EL1_TGRAN4_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_64kb_granule’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:698:40: error: ‘SYS_ID_AA64MMFR0_EL1’ undeclared (first use in this function)
698 | mmfr0 = read_sanitised_ftr_reg(SYS_ID_AA64MMFR0_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:700:49: error: ‘ID_AA64MMFR0_EL1_TGRAN64_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
700 | ID_AA64MMFR0_EL1_TGRAN64_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_16kb_granule’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:711:40: error: ‘SYS_ID_AA64MMFR0_EL1’ undeclared (first use in this function)
711 | mmfr0 = read_sanitised_ftr_reg(SYS_ID_AA64MMFR0_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:713:49: error: ‘ID_AA64MMFR0_EL1_TGRAN16_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
713 | ID_AA64MMFR0_EL1_TGRAN16_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_mixed_endian_el0’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:721:69: error: ‘SYS_ID_AA64MMFR0_EL1’ undeclared (first use in this function)
721 | return id_aa64mmfr0_mixed_endian_el0(read_sanitised_ftr_reg(SYS_ID_AA64MMFR0_EL1));
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_mixed_endian’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:729:40: error: ‘SYS_ID_AA64MMFR0_EL1’ undeclared (first use in this function)
729 | mmfr0 = read_sanitised_ftr_reg(SYS_ID_AA64MMFR0_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:731:49: error: ‘ID_AA64MMFR0_EL1_BIGEND_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
731 | ID_AA64MMFR0_EL1_BIGEND_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_sme’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:762:37: error: ‘ARM64_SME’ undeclared (first use in this function); did you mean ‘ARM64_SVE’?
762 | cpus_have_const_cap(ARM64_SME);
| ARM64_SVE
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_sme2’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:768:37: error: ‘ARM64_SME2’ undeclared (first use in this function); did you mean ‘ARM64_SVE’?
768 | cpus_have_const_cap(ARM64_SME2);
| ARM64_SVE
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_supports_fa64’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:774:37: error: ‘ARM64_SME_FA64’ undeclared (first use in this function)
774 | cpus_have_const_cap(ARM64_SME_FA64);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘system_uses_irq_prio_masking’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:808:36: error: ‘ARM64_HAS_GIC_PRIO_MASKING’ undeclared (first use in this function); did you mean ‘ARM64_HAS_IRQ_PRIO_MASKING’?
808 | cpus_have_const_cap(ARM64_HAS_GIC_PRIO_MASKING);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘id_aa64mmfr0_parange_to_phys_shift’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:840:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_32’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
840 | case ID_AA64MMFR0_EL1_PARANGE_32: return 32;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:841:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_36’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
841 | case ID_AA64MMFR0_EL1_PARANGE_36: return 36;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:842:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_40’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
842 | case ID_AA64MMFR0_EL1_PARANGE_40: return 40;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:843:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_42’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
843 | case ID_AA64MMFR0_EL1_PARANGE_42: return 42;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:844:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_44’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
844 | case ID_AA64MMFR0_EL1_PARANGE_44: return 44;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:845:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_48’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
845 | case ID_AA64MMFR0_EL1_PARANGE_48: return 48;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:846:14: error: ‘ID_AA64MMFR0_EL1_PARANGE_52’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_PARANGE_MAX’?
846 | case ID_AA64MMFR0_EL1_PARANGE_52: return 52;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘cpu_has_hw_af’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:870:40: error: ‘SYS_ID_AA64MMFR1_EL1’ undeclared (first use in this function)
870 | mmfr1 = read_sanitised_ftr_reg(SYS_ID_AA64MMFR1_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:872:49: error: ‘ID_AA64MMFR1_EL1_HAFDBS_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
872 | ID_AA64MMFR1_EL1_HAFDBS_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘cpu_has_pan’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:230:55: error: ‘SYS_ID_AA64MMFR1_EL1’ undeclared (first use in this function)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:877:21: note: in expansion of macro ‘read_cpuid’
877 | u64 mmfr1 = read_cpuid(ID_AA64MMFR1_EL1);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:879:53: error: ‘ID_AA64MMFR1_EL1_PAN_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
879 | ID_AA64MMFR1_EL1_PAN_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h: In function ‘get_vmid_bits’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:900:49: error: ‘ID_AA64MMFR1_EL1_VMIDBits_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
900 | ID_AA64MMFR1_EL1_VMIDBits_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cpufeature.h:901:26: error: ‘ID_AA64MMFR1_EL1_VMIDBits_16’ undeclared (first use in this function)
901 | if (vmid_bits == ID_AA64MMFR1_EL1_VMIDBits_16)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/irqflags.h: In function ‘__irqflags_uses_pmr’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/irqflags.h:27:45: error: ‘ARM64_HAS_GIC_PRIO_MASKING’ undeclared (first use in this function); did you mean ‘ARM64_HAS_IRQ_PRIO_MASKING’?
27 | alternative_has_cap_unlikely(ARM64_HAS_GIC_PRIO_MASKING);
In file included from <command-line>:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cache.h: In function ‘cache_type_cwg’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cache.h:80:30: error: ‘CTR_EL0_CWG_MASK’ undeclared (first use in this function)
80 | return SYS_FIELD_GET(CTR_EL0, CWG, read_cpuid_cachetype());
/usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/compiler_types.h:442:23: note: in definition of macro ‘__compiletime_assert’
442 | if (!(condition)) \
/usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/compiler_types.h:462:9: note: in expansion of macro ‘_compiletime_assert’
462 | _compiletime_assert(condition, msg, __compiletime_assert_, __COUNTER__)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/build_bug.h:39:37: note: in expansion of macro ‘compiletime_assert’
39 | #define BUILD_BUG_ON_MSG(cond, msg) compiletime_assert(!(cond), msg)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/bitfield.h:65:17: note: in expansion of macro ‘BUILD_BUG_ON_MSG’
65 | BUILD_BUG_ON_MSG(!__builtin_constant_p(_mask), \
/usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/bitfield.h:154:17: note: in expansion of macro ‘__BF_FIELD_CHECK’
154 | __BF_FIELD_CHECK(_mask, _reg, 0U, "FIELD_GET: "); \
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/sysreg.h:1115:18: note: in expansion of macro ‘FIELD_GET’
1115 | FIELD_GET(reg##_##field##_MASK, val)
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cache.h:80:16: note: in expansion of macro ‘SYS_FIELD_GET’
In file included from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/bits.h:6,
from /home/pi/Desktop/Neu/ad4000.c:7:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cache.h: In function ‘read_cpuid_effective_cachetype’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cache.h:116:25: error: ‘CTR_EL0_IDC_SHIFT’ undeclared (first use in this function); did you mean ‘SCTLR_ELx_EE_SHIFT’?
116 | if (!(ctr & BIT(CTR_EL0_IDC_SHIFT))) {
/usr/src/linux-headers-6.6.74+rpt-common-rpi/include/vdso/bits.h:7:44: note: in definition of macro ‘BIT’
7 | #define BIT(nr) (UL(1) << (nr))
In file included from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h:11,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/processor.h:39,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/rcupdate.h:31:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/virt.h: In function ‘has_hvhe’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/virt.h:151:36: error: ‘ARM64_KVM_HVHE’ undeclared (first use in this function)
151 | return cpus_have_final_cap(ARM64_KVM_HVHE);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h: In function ‘get_num_brps’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h:142:43: error: ‘SYS_ID_AA64DFR0_EL1’ undeclared (first use in this function); did you mean ‘SYS_ICC_AP1R0_EL1’?
142 | u64 dfr0 = read_sanitised_ftr_reg(SYS_ID_AA64DFR0_EL1);
| SYS_ICC_AP1R0_EL1
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h:145:49: error: ‘ID_AA64DFR0_EL1_BRPs_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
145 | ID_AA64DFR0_EL1_BRPs_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h: In function ‘get_num_wrps’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h:151:43: error: ‘SYS_ID_AA64DFR0_EL1’ undeclared (first use in this function); did you mean ‘SYS_ICC_AP1R0_EL1’?
151 | u64 dfr0 = read_sanitised_ftr_reg(SYS_ID_AA64DFR0_EL1);
| SYS_ICC_AP1R0_EL1
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/hw_breakpoint.h:154:49: error: ‘ID_AA64DFR0_EL1_WRPs_SHIFT’ undeclared (first use in this function); did you mean ‘ID_AA64MMFR0_EL1_TGRAN_SHIFT’?
154 | ID_AA64DFR0_EL1_WRPs_SHIFT);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/mte-kasan.h: In function ‘mte_set_mem_tag_range’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/cputype.h:230:55: error: ‘SYS_DCZID_EL0’ undeclared (first use in this function); did you mean ‘SYS_MDCCSR_EL0’?
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/mte-kasan.h:157:17: note: in expansion of macro ‘read_cpuid’
157 | dczid = read_cpuid(DCZID_EL0);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/processor.h: In function ‘thread_get_cur_vl’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/processor.h:202:54: error: ‘SVCR_SM_MASK’ undeclared (first use in this function); did you mean ‘TCR_SH0_MASK’?
202 | if (system_supports_sme() && (thread->svcr & SVCR_SM_MASK))
| TCR_SH0_MASK
In file included from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/processor.h:374:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h: In function ‘thread_sm_enabled’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h:79:57: error: ‘SVCR_SM_MASK’ undeclared (first use in this function); did you mean ‘TCR_SH0_MASK’?
79 | return system_supports_sme() && (thread->svcr & SVCR_SM_MASK);
| TCR_SH0_MASK
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h: In function ‘thread_za_enabled’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h:84:57: error: ‘SVCR_ZA_MASK’ undeclared (first use in this function)
84 | return system_supports_sme() && (thread->svcr & SVCR_ZA_MASK);
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h: In function ‘write_vl’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h:225:37: error: ‘SYS_ZCR_EL1’ undeclared (first use in this function); did you mean ‘SYS_TCR_EL1’?
225 | tmp = read_sysreg_s(SYS_ZCR_EL1) & ~ZCR_ELx_LEN_MASK;
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/fpsimd.h:225:53: error: ‘ZCR_ELx_LEN_MASK’ undeclared (first use in this function)
In file included from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/uaccess.h:24,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/uaccess.h:11,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/sched/task.h:11,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/sched/signal.h:9,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/rcuwait.h:6,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/percpu-rwsem.h:7,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/fs.h:33,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/elf.h:141,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/elf.h:6,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/module.h:19,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/device/driver.h:21,
from /usr/src/linux-headers-6.6.74+rpt-common-rpi/include/linux/device.h:32:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/mte.h: In function ‘mte_disable_tco_entry’:
/usr/src/linux-headers-6.6.74+rpt-common-rpi/arch/arm64/include/asm/mte.h:176:48: error: ‘SCTLR_EL1_TCF0_SHIFT’ undeclared (first use in this function); did you mean ‘SCTLR_ELx_ENIA_SHIFT’?
176 | (task->thread.sctlr_user & (1UL << SCTLR_EL1_TCF0_SHIFT)))
/home/pi/Desktop/Neu/ad4000.c: In function ‘ad4000_read_raw’:
/home/pi/Desktop/Neu/ad4000.c:361:17: error: implicit declaration of function ‘iio_device_claim_direct_scoped’; did you mean ‘iio_device_claim_direct_mode’? [-Werror=implicit-function-declaration]
361 | iio_device_claim_direct_scoped(return -EBUSY, indio_dev)
/home/pi/Desktop/Neu/ad4000.c:361:48: error: expected expression before ‘return’
/home/pi/Desktop/Neu/ad4000.c:361:73: error: expected ‘;’ before ‘return’
362 | return ad4000_single_conversion(indio_dev, chan, val);
/home/pi/Desktop/Neu/ad4000.c: In function ‘ad4000_write_raw’:
/home/pi/Desktop/Neu/ad4000.c:419:48: error: expected expression before ‘return’
419 | iio_device_claim_direct_scoped(return -EBUSY, indio_dev) {
/home/pi/Desktop/Neu/ad4000.c:419:73: error: expected ‘;’ before ‘{’ token
/home/pi/Desktop/Neu/ad4000.c:415:13: warning: unused variable ‘ret’ [-Wunused-variable]
415 | int ret;
/home/pi/Desktop/Neu/ad4000.c:414:14: warning: unused variable ‘span_comp_en’ [-Wunused-variable]
414 | bool span_comp_en;
/home/pi/Desktop/Neu/ad4000.c:413:22: warning: unused variable ‘reg_val’ [-Wunused-variable]
413 | unsigned int reg_val;
/home/pi/Desktop/Neu/ad4000.c:412:30: warning: unused variable ‘st’ [-Wunused-variable]
412 | struct ad4000_state *st = iio_priv(indio_dev);
/home/pi/Desktop/Neu/ad4000.c: In function ‘ad4000_prepare_3wire_mode_message’:
/home/pi/Desktop/Neu/ad4000.c:505:16: error: implicit declaration of function ‘devm_spi_optimize_message’ [-Werror=implicit-function-declaration]
505 | return devm_spi_optimize_message(&st->spi->dev, st->spi, &st->msg);
/home/pi/Desktop/Neu/ad4000.c: In function ‘ad4000_probe’:
/home/pi/Desktop/Neu/ad4000.c:571:15: error: implicit declaration of function ‘devm_regulator_get_enable_read_voltage’; did you mean ‘devm_regulator_get_enable_optional’? [-Werror=implicit-function-declaration]
571 | ret = devm_regulator_get_enable_read_voltage(dev, "ref");
/home/pi/Desktop/Neu/ad4000.c:582:15: error: implicit declaration of function ‘device_property_match_property_string’; did you mean ‘device_property_match_string’? [-Werror=implicit-function-declaration]
582 | ret = device_property_match_property_string(dev, "adi,sdi-pin",
/home/pi/Desktop/Neu/ad4000.c:601:30: error: ‘SPI_MOSI_IDLE_HIGH’ undeclared (first use in this function); did you mean ‘SPI_MOSI_IDLE_LOW’?
601 | spi->mode |= SPI_MOSI_IDLE_HIGH;
| SPI_MOSI_IDLE_LOW
/home/pi/Desktop/Neu/ad4000.c: At top level:
/home/pi/Desktop/Neu/ad4000.c:327:12: warning: ‘ad4000_single_conversion’ defined but not used [-Wunused-function]
327 | static int ad4000_single_conversion(struct iio_dev *indio_dev,
/home/pi/Desktop/Neu/ad4000.c:292:12: warning: ‘ad4000_read_reg’ defined but not used [-Wunused-function]
292 | static int ad4000_read_reg(struct ad4000_state *st, unsigned int *val)
cc1: some warnings being treated as errors
make[3]: *** [/usr/src/linux-headers-6.6.74+rpt-common-rpi/scripts/Makefile.build:248: /home/pi/Desktop/Neu/ad4000.o] Fehler 1
make[2]: *** [/usr/src/linux-headers-6.6.74+rpt-common-rpi/Makefile:1946: /home/pi/Desktop/Neu] Fehler 2
make[1]: *** [/usr/src/linux-headers-6.6.74+rpt-common-rpi/Makefile:246: __sub-make] Fehler 2
make[1]: Verzeichnis „/usr/src/linux-headers-6.6.74+rpt-rpi-2712“ wird verlassen
make: *** [Makefile:7: all] Fehler 2
Could someone help me with this.
