We’re looking to use the AD74413R IC to receive 4-20mA signals from a sensor/transmitter. Kindly share your comments on the following queries:
If the current loop is powered or a 2-wire loop, will we need to provide 24V to the AVDD?
Is it possible to mix 2-wire (loop-powered) and 3-wire/4-wire loops on the same IC? What design considerations should be taken into account for this configuration?
In a 2-wire loop system, is it possible for the device(s) on the loop to be powered from the AVDD supply?
Thanks
Mukesh
