HI.
EVAL-AD7124-4SDZ is used to evaluate temperature measurement.
My question is, is the conversion formula to temperature in the software the same whether we use thermocouples or RTDs?
AD7124-4
Recommended for New Designs
The AD7124-4 is a low power, low noise, completely integrated analog front end for high precision measurement applications. The device contains a low noise...
Datasheet
AD7124-4 on Analog.com
HI.
Hi YJI ,
The formulas that you are looking at are used for the ADC's Internal Temperature Sensor and there is a different temperature conversion formula used for RTDs and Thermocouples.
You may use these CFTLs as a reference:
CN-0383 (Rev.D)
CN-0384 (Rev. A)
This contains the temperature conversion formula and this may serve as your reference design for your setup/system.
Thanks and regards,
Rod
